2
Make a photo fade to transparency?
Guest
Nov 25, 2010 Nov 25, 2010
Hi, just wondering if it's possible to fade a photo (not a box of colour) to transparency in Illustrator? I am familiar with how to do it in InDesign and Photoshop - but not knowing how to do it in Illustrator.
Every online tut I have found just explains how to fade "a colour" - versus an actual photo place in an illustrator document.
Any insight?
Thank you,
Chemol
136.0K
Community Expert , Nov 25, 2010 Nov 25, 2010
Draw a rectangle on top of the raster image, apply a black to white gradient to that rectangle, select both the rectangle and the raster image, then go to the Transparency Palette and create an opacity mask. That's the basic principle.
Adobe
Does the version of Illustrator you are using support opacity masks?
Guest
I am using CS4 - I believe it does
Guest
Thanks a bundle! I was attempting it that way before, but for some reason it
didn¹t turn out properly ­ I appreciate your insight!
Happy Turkey day
Chemol
Nov 11, 2014 Nov 11, 2014
Is there an echo in here? haha
May 25, 2016 May 25, 2016
Hi Kurt Gold,
Thanks for your answer, was great. So I've done as you said, but now how to I control that fade out - the fade starts too soon over my image and is basically covering most of it. See my image attached 😃
Thanks 😃
May 26, 2016 May 26, 2016
select your masked image. click on the mask in the transparency panel (red circle below). then adjust the gradient with either the gradient tool or palette.
select the image again in the transparency palette when you're done too, otherwise anything you draw after with just be added to the mask (and you won't see it).
Thank you; much appreciated 😃
Jan 16, 2020 Jan 16, 2020
Can anyone explain how I would select the image if it's already got the rectangle over it?
Jan 17, 2020 Jan 17, 2020
In the transparency panel, you can either select the mask or the underlying object by clicking on either of the two thumbnails.
Mar 22, 2016 Mar 22, 2016
Thanks a whole lot. Worked for me though!
Aug 07, 2016 Aug 07, 2016
This process doesnt work when exporting to PDF
Aug 08, 2016 Aug 08, 2016
Which process exactly does not work in which way exactly when saving to what kind of PDF exactly and which application do you use to check the PDF?
