Hi All
I want to programmatically add an XDP letter template to the ES 2.5 correspondance management system, is there an API or WS to enable this to happen?
Regards
Kev
Total Likes
CM has a Form (XDP template) as well as a Letter (Correspondence Template that uses a Form) - Not sure which one you are looking for when you said “XDP letter template” [but my guess is that it’s the former that you may be looking for].
So, if you are looking to add an XDP template, i.e., create a Form, you may use the FormService APIs (createForm(…)) to do so. And in case you are looking to create a Letter you should be using the LetterService APIs (createLetter(…)).
These APIs (available in the adobe-acm-client.jar in your installation’s client libs) are exposed as Spring beans, as part of the Asset Composer building block.
(you can easily expose a Spring bean as a Web Service - http://static.springsource.org/spring/docs/2.0.x/reference/remoting.html)
Total Likes
Kevin,
You can go through java docs
http://help.adobe.com/en_US/LiveCycle/9.5/SolutionAcceleratorsAPI/com/adobe/icc/services/api/FormSer... (create Form)
http://help.adobe.com/en_US/LiveCycle/9.5/SolutionAcceleratorsAPI/com/adobe/icc/services/api/LetterS... (create Letter)
Santosh
Total Likes
