Show 3 replies
1. Re: Can't render a PE7 Project with PE9. How can I fix?
Bill Hunt Nov 27, 2010 10:36 AM (in response to TRUE_SEEKER)On your Timeline, do you have the WAB (Work Area Bar) set to less than the full Duration of the Timeline? This will limit what part of the Timeline will be Rendered.
Good luck,
Hunt
2. Re: Can't render a PE7 Project with PE9. How can I fix?
TRUE_SEEKER Nov 27, 2010 11:30 AM (in response to Bill Hunt) -
3. Re: Can't render a PE7 Project with PE9. How can I fix?
Steve Grisetti Nov 27, 2010 2:24 PM (in response to TRUE_SEEKER)This is typical of the buggy behavior people see when they open an older version project with a newer version of the program.
That's why I always recommend against doing it. (Of, if you do, make sure you save a copy of the original project file so you can go back if things go wrong.) It almost always leads to problems.
