Use either Reduce File Size under the Document Menu or PDF Optimize under the Advanced>Print Production menu. However, a 50:1 compression may not be possible without a substantial loss in the result. Also, if the PDF is a set of graphics of text, not actual text, then using OCR with clearscan may be the first step to take. Often such large files are scanned files and the OCR to ClearScan is the first step to take.
I have selected Printer Adobe PDF, under Adobe PDF Document Properties Menu, I picked Adobe PDF Setting tab. Then I editted the Default Settings as below:-
I managed to reduced the original size from 92MB to 3.6MB, however, the images were downsized tremendously.
Depending on the content of your PDF and such, your selection is not unreasonable. However, the smallest-size job options does not embed fonts. You have to be extremely careful in such a case that you are not using any strange fonts that users of your PDF may not have.
If you can compromise on graphics output, then down sample the graphics in a photo editing software like photoshop, then create a new file with the edited graphics. Also flatten the layers in Acrobat. Do not embed the fonts.
I do not intend to edit it in Photoshop since it is already a final pdf file. I need a fast solution and method to shrink the pdf to email. Compromising the image resolution is permitted. Thanks a lot.
You may have to extract parts of the PDF and e-mail the parts. That may be the best solution if you are under time pressure.
