Hi Rannveig
Typically it goes like this.
1. Insert RelatedTopics control and note name by hovering the
control. Should be RelatedTopics if it is the first, object1 or
OBJECT1 if the second (depending on how the control was inserted)
2. Select the text your user will click to activate the
control and perform the same steps as if you were linking to
another page.
3. In the Hyperlink dialog, instead of listing the path to
the page, type JavaScript:RelatedTopics.Click(). Note that if the
control name is object1 or OBJECT1, you substitute this for
RelatedTopics.
Hopefully this helps... Rick
