I'm trying to figure out how the LiveCycle 9.5 connector for sharepoint works. It all works like a charm, exept for the set document content activity in a LiveCycle process.
When I have a file named test.txt on my Sharepoint server, and I execute the process with the "set document content" activity to replace the content with the content of the same test.txt files' content which I changed for the experiment, it gets updated without any problems.
Yet, when I have a file named test.docx on my Sharepoint server, and I try to replace the content with that of the content of the same test.docx file with altered content, the document content doesn't get updated to the new content.
Is there a certain configuration that I need to do, to make this work or is this a known issue of the connector?
Thanks in advance for your answer
Kind Regards,
Ronald Kamp
Junior Flex/Java/LiveCycle Consultant at iDA MediaFoundry.
Total Likes
Hi Ronald,
I could not get this reproduced at my end. We were successfully able to replace contents of a .docx file as well.
Can you please attach the livecycle process along with the thread in case issue has not yet been resolved at your side?
Raghu
Total Likes
