I would like to generate a log to track the names and outcomes of files processed from a watched folder. I don't see a way to access the name of the file from within the process. I have a variable "inPDF" which is data type "document" and "outResult" which is type "xml" but I don't see a way to access the file name (or path) of the "inPDF" "document" object. Is there a way to access the file name and path?
Solved! Go to Solution.
Total Likes
The document's name and path can be accessed using the document's attributes. If you are using a process, you can use a SetValue operation and get the attributes using the getDocAttribute function (under Functions/Document Object Functions). There are three attributes that are of interest:
basename - gives you just the file name
file - gives the filename and the path (usually from the stage directory)
wsfilename - the filename for workspace, in most cases the same as file.
Total Likes
You can use xPath and use the function getDocAttribute (/process_data/@inDoc,"filename") to get the attribute into a string.
Jasmin
Total Likes
Thank you, this sounds promising.
Where can I find documentation describing the attributes that can be retrieved using the getDocumentAttribute function? Also, where can I find a complete reference on the Document object?
Best Regards,
Noam
Total Likes
There isn't really a set list of attributes because the document object allows anyone to add thier own (setAttribute). You can get a list of all the ones set on a existing document using the listAttributes function. Here is some useful documentation:
The official documentation has info on the document functions:
The attributes used by attachments and notes (Workspace type attributes):
The JavaDocs for the 9.0 (LiveCycle ES2) document object:
http://help.adobe.com/en_US/livecycle/9.0/programLC/javadoc/com/adobe/idp/Document.html
