Hello everybody,
Recently i was asked to use robohelp to create webhelp. Right now am stuck with a part where, in each of topics i need to have topic name as header and a button at footer in all topic files. for the common button, can make use of master page. but when it comes to header, is ther any way to have different header names for each topics. if am using master page, then it only allows me to use common names for all.
ANy help would be appreciated.
Thanks in advance
HIthesh
You want the name of the topic (xxx.htm) to show in the top of your page? You can use a variable for that. (Insert > User Defined Variable ) You can add the variable to the master page and the variable takes the correct value according to the page name. You can add the page name, page title, date/time or a custom variable.
Greet,
Willam
That was helpful. Thanks W. Van Weelden.
