Hi all,
I have a dynamic PDF in LiveCycle Designer with subforms flowing on a page.
In my first subform I created some checkboxes to toggle the visibility of a subform. But the next subform contains also checkboxes. When I check one in the first subform the additional subform appears. But I cannot check additional checkboxes anymore.
To make it clear:
Subform
Subform Checkbox1 Checkbox2 Checkbox3 Checkbox4
Subform Checkbox5 Checkbox6 Checkbox7 Checkbox8
Subform Checkbox9 Checkbox10 hidden till Checkbox 1 or 2 is checked
I can activate Checkbox1 ok. Subform appears, correct.
If I try to activate Checkbox5 Checkbox1 is deactivated? I could not see my mistake.
Can anybody help?
Thanks a lot.
Sabine
Total Likes
I made it.
I don't know why. But I had to delete all checkboxes and create them new.
It only works in nested subforms if you create all checkboxes direktly in one step. If you format one and then create a new one it behaves like an option.
Could this be a bug?
Sabine
Total Likes
How do you create / delete the checkboxes?
greets
Total Likes
I did activate them in hierarchy and used keyboard key del.
Then drag and drop new ones from objects panel.
After placing them I formatted them.
The original file was created like this. Create one checkbox and copy it several times. Then renaming them.
I coul verify in another form that I never can copy a checkbox.
Still the same problems.
Sabine
Total Likes
