Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Multi Digital Signature
Avatar
Level 2
Hi to all,
I create a Form using Adobe LiveCycle Designer 8.2. The purpose of this form is to have multiple digital signatures from 4 different people. But when the first person fills the form and does a digital signature. The second, third and forth cannot do the digital signature. I’m the only one that can do the rest of the digital signature. I try many thinks like lock and unlock the signature field without any luck. Please if someone can let me know what I can do will appreciate. Thanks.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
That's correct.  Reader can only be used to sign PDFs that have been "Reader Extended".  This can be done with LiveCycle Reader Extensions ES2, or in cases where (I think) less than 500 people will be using the "extended" document, Acrobat Professional can be used to enable signatures with Reader.
Regards
Steve
Avatar
Did you enable\disable the "Lock Fields After Signing" option for the signature field(s)? (see screen shot)
Did you configure any seed values for the signaturte field(s)
Can you post a copy of the the form?
Reagrds
Steve
Avatar
Level 2
Thanks Steve,
Yes, I try disable and enable the “Lock Fields after Signing” and I also create a custom one but it doesn’t work.
No, I didn’t configure any seed values. Do I have to? If, so how can I do it?
How can I post the copy? I try to do a screen shot but it was to big....
Alex
Avatar
Level 2
Steve,
This is the form.
Alex
Avatar
I took a quick look at the form, it appears to be working fine.  I am able to sign it (using Acrobat), and then subsequently sign the remaining signature fields.
Are you using Acrobat to do the testing?  Remember, you can't sign a PDF with Adobe Reader unless the form has been Reader Extended to enable Adobe Reader to sign PDFs.
Regards
Steve
Avatar
From "alexvj"
Yes, I have Acrobat, but the user have only Adobe reader. So I just need to change it to reader extended?
Alex
Avatar
Correct answer by
Regards
Steve
Avatar
Level 2
It work!!! Thank you so much Steve....:)
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
