I am having trouble figuring out something that is very common in other languages: how to read a local text file. Can somebody enlighten me on how to do this in Flex 4? Thanks!
There are a number of ways to achieve this. Can you be more specific as to what you mean by "local"
Is the file local to the file system that the SWF is running (i.e. on the server) or is the file a local file on the end-user's machine that they have to select with a File Browser?
By "local file system" I am referring to a text file that resides in the same directory on the server as the swf. I simply want to apply some configuraiton settings to my application. Thanks...
One way to do it would be to use the URLLoader class:
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/net/URLLoader.html
//params.txt is a local file that includes: firstName=Tom&lastName=Jones var lbl:TextField = new TextField(); var urlRequest:URLRequest = new URLRequest("params.txt"); var urlLoader:URLLoader = new URLLoader(); urlLoader.dataFormat = URLLoaderDataFormat.VARIABLES; urlLoader.addEventListener(Event.COMPLETE, urlLoader_complete); urlLoader.load(urlRequest); function urlLoader_complete(evt:Event):void { lbl.text = urlLoader.data.lastName + "," + urlLoader.data.firstName; addChild(lbl); }
Or my personal favourite is to create a proper class and event to handle the loading of XML content...
[XMLContentLoader.as]
package
import flash.events.Event;
import flash.events.HTTPStatusEvent;
import flash.events.IOErrorEvent;
import flash.events.SecurityErrorEvent;
import flash.net.URLLoader;
import flash.net.URLLoaderDataFormat;
import flash.net.URLRequest;
import flash.net.URLRequestMethod;
import flash.xml.XMLDocument;
import mx.controls.Alert;
import mx.rpc.xml.SimpleXMLDecoder;
[Event(name="loadContent", type="XMLContentLoaderEvent")]
[Event(name="contentLoaded", type="XMLContentLoaderEvent")]
[Event(name="loadContentError", type="XMLContentLoaderEvent")]
* An XML Content Loader, that can load xml file and parse it to an
* Object which will be dispatched with the Content Loaded event.
public class XMLContentLoader extends URLLoader
* XML file url
public var url:String="";
/** * * XML Content Loader state variable */ public var state:int;
* @Constructor
public function XMLContentLoader()
this.dataFormat = URLLoaderDataFormat.TEXT;
super();
* Start to load content
public function sendRequest():void
try
var _request:URLRequest = new URLRequest();
_request.url = this.url;
_request.method = URLRequestMethod.GET;
this.addEventListener(Event.COMPLETE, onResultHandler);
this.addEventListener(HTTPStatusEvent.HTTP_STATUS, httpStatusHandler);
this.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
this.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
this.load(_request);
var ev:XMLContentLoaderEvent = new XMLContentLoaderEvent(XMLContentLoaderEvent.LOAD_CONTENT);
dispatchEvent(ev);
catch(e:Error)
trace("Unable to load URL: "+this.url);
Alert.show("Unable to load URL: "+this.url, "XML Load Error");
* On content loaded handler.
private function onResultHandler(event:Event):void
var ev:XMLContentLoaderEvent = new XMLContentLoaderEvent(XMLContentLoaderEvent.CONTENT_LOADED);
ev.data = convertXMLtoArrayCollection(new XMLDocument(event.target.data));
ev.rawEvent = event;
dispatchEvent(ev);
private function httpStatusHandler (e:HTTPStatusEvent):void
this.state = e.status;
private function securityErrorHandler (e:SecurityErrorEvent):void
trace("securityErrorHandler:" + e);
Alert.show("securityErrorHandler:" + e, "XML Load Error");
private function ioErrorHandler(e:IOErrorEvent):void
var ev:XMLContentLoaderEvent = new XMLContentLoaderEvent(XMLContentLoaderEvent.LOAD_CONTENT_ERROR);
ev.rawEvent = e;
dispatchEvent(ev);
trace("ioErrorHandler: " + e);
Alert.show("ioErrorHandler: " + e, "XML Load Error");
private function convertXMLtoArrayCollection(xmlDoc:XMLDocument):Object
var decoder:SimpleXMLDecoder = new SimpleXMLDecoder;
var data:Object = decoder.decodeXML(xmlDoc);
return data;
[XMLContentLoaderEvent.as]
package
public class XMLContentLoaderEvent extends Event
* The xml file content will be converted and stored into this object.
public var data:Object;
* All original event info is saved in this variable.
public var rawEvent:Event;
* @default
public static const LOAD_CONTENT:String = "loadContent";
* @default
public static const CONTENT_LOADED:String = "contentLoaded";
* @default
public static const LOAD_CONTENT_ERROR:String = "loadContentError";
* @param type
* @param bubbles
* @param cancelable
public function XMLContentLoaderEvent(type:String, bubbles:Boolean=false, cancelable:Boolean=false)
super(type, bubbles, cancelable);
* @private
override public function clone():Event
var event:XMLContentLoaderEvent = new XMLContentLoaderEvent(type, bubbles, cancelable);
event.data = data;
event.rawEvent = rawEvent;
return event;
