This is likely a basic question but I can't find the answer anywhere - and I apologize if this should be the Acro forms forum.
I completed a rather simple form using Livecycle where the user enters data and a script adds it up and places it in a "total" field. I saved as a dynamic pdf and tested it out fine. I sent it out to a few clients and a few advised me that the total field wasn't being populated after they entered data - the other clients sent back completed forms so I know it worked for some but not for all. One client stated that they recieved a message stated that they had to enable java in order for the form to work (not the exact wording) and they ok'd it but the form still didn't work.
I can't imagine that each end user needs certain settings or updated java to use a form (or maybe I'm wrong). I'm thinking I have to do something on my end before sending it out so the form always works.
Any advice would be appreciated.
Andrew
Total Likes
There is an Acrobat/Reader setting that allows the user to disable javascript. I think this is wha
t is happening to you.
Paul
Total Likes
