Accessing Admin UI
Avatar
Level 2
My questions might seem very basic as I am semi-technical + business combo. I seem to have set-up the appliance in VMWare Workstation along with settings related to jboss. I am looking to get further understanding on accessing adminui. I know that you have specified <your_IP_address>. But that doesn't seem to work. Are you refering to IP address of appliance. I hope to have your feedback so that I can get this up and running. Please bear in mind my background when you reply so that we don't have to go back and forth. Thanks for your help.
Avatar
Level 7
Yes, you need to replace <your_IP_address> with the IP address the appliance has (hopefully) picked up from your network's DHCP server (assuming that is what you chose to do when the appliance was started for the first time).
Start the command prompt of the appliance (it is SUSE Enterprise Linux 11), switch to the 'root' user and run the command 'ifconfig' which should tell you the IP address of the appliance.  Instructions on these are available in the readme here:
http://d2x45prcet210j.cloudfront.net/readme.pdf
Avatar
Level 2
Appreciate  your quick help. Could you possibly suggest
if this address needs to be typed inside browser provided by
appliance or the main system where the appliance is housed ?
Avatar
Level 7
From the "main system where the appliance is housed", or any other desktop in the same network.
Avatar
Level 2
Well, I guess it did pick ip address from DHCP server, but here
's what I am getting as error. (XX are protected for pricvacy)
The requested URL could not be retrieved
While trying to retrieve the URL: http://XX.XX.XX:8080/adminui
The following error was encountered:
We can not connect to the server you have requested.
This means that:
  • The server might be busy at this time.
  • The server is not reachable.
Please try later to see if you can go through.
Avatar
Level 7
Please e-mail me directly at first name . last name at adobe . com so that I can contact you. Thanks.
- Jayan
Avatar
Level 2
So, I have been able to get it up and running !!!! Yay !!!
As I accessing different options, one of the places that
I am exploring is rights management. I am not able to login right manageme
nt page with 'administrator' and 'password' login/password. Anything I am missing here ?
Thanks in advance.
Avatar
Level 7
This is as designed - the "Administrator" super user cannot login to that UI (/edc/Login.do).
You have to first create a user with the role of "LiveCycle Rights Management User" using the AdminUI.
Avatar
Level 2
Well, the other thing that I stumbled upon while looking at rights management is the need to configure ssl. After following the steps mentioned in readme, I am not been able to kick-off jboss again. what potentially can i be missing ?
Avatar
Level 7
Most probably a mistake was made while editing the XML file.  Can you post the exception in JBoss boot.log?
Avatar
Level 2
One of them is BMC001, port 1098 and port 4444 already in use....is this  because of recent changes ?
Avatar
Level 7
That means JBoss is already running.  Re-start the VM.
Avatar
Level 1
What is the username password to login to adminui please?
Thanks.
