1. Re: Change spread in indesign
P Spier Dec 13, 2010 10:04 AM (in response to Lena P)Selct the spread inthe Pages panel, then right click or open the panel menu and choose Rotate Spread View...
The pages will rotate in the document window, but not in the panel.
2. Re: Change spread in indesign
Lena P Dec 13, 2010 10:45 AM (in response to P Spier)I don´t seem to be able to find a way to respond directly in the forum
therefore I reply to this mail.
I do not want to only rotate the view, I would like to acuallty rotate the
whole spread. I want the spread to contain of 2 landcape A4 exactly as my
picture shows.
Is that possible?
Regards - Lena Palmberg
3. Re: Change spread in indesign
P Spier Dec 13, 2010 10:51 AM (in response to Lena P)In Design does not have a direct facility to bind on the top edge of a landcape page. Set up and two portrait pages and rotate the view. While you work you will not be aware that you are actually working in portrait pages. The display will look and behave as if you are working in stacked landscape pages.
As far as I know, no layout program does a top-binding layout option.
4. Re: Change spread in indesign
Lena P Dec 13, 2010 11:10 AM (in response to P Spier)Ok, I understand what you say and that is true. But the actual reason for my
question is that I would like to use the flash page transition and would
then like the page to turn from bottom left and then on a spread that looks
like my picture. Do you know if there is a possibility for that? I don´t
seem to be able to change the position of the flash page transition. Do you
understand what I mean?
Regards - Lena
5. Re: Change spread in indesign
P Spier Dec 13, 2010 11:17 AM (in response to Lena P)I'm afraid I can't help you with that one.
