Can I disable the breadcrumbs in pop-up boxes? If so, how? In this example, I want to remove the breadcrumb reference:
Please let me know.
Hi there
What version of RoboHelp are you using? What RoboFlavor? We have outlined what you should insert in posts at the link below:
I'm guessing you didn't read that, so now we must ask more questions and delay the answer.
Cheers... Rick
Helpful and Handy Links |
I apologize, and no, I did not read the helpful hints (shame). So...
I am working in RH8 / RoboHelp for HTML.
Cindy
Thanks for the info.
In RoboHelp 8 Breadcrumbs are handled in new ways. (That's why I needed to know the version.)
We still don't know how you have implemented them, so I'll just outline how each way works.
Hopefully this helps... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Got it. Love it! Hope I have time to go back to my existing files topic files and make the change! Is there some way to re-apply to existing topics which have used the templates?
Cindy
Hi Cindy.
All you need to do is amend the template. When you save it you'll be asked whether you wish to amend all the topics to which the template is attached. Click Yes and you're done.
Read the RoboColum(n).
Colum -
When I saved my changes, I was not prompted to apply the changes to all of the topics to which the Master Page is attached. Is there another option?
Hi there
It's been my experience that this will only happen under the following conditions:
You are editing a topic that has a Master Page / Topic Template associated with it and you edit one of the options outside the Main Body placeholder (Header / Footer). If you do this, RoboHelp tosses up a message asking if you want to make this topic different or if you want to update the Master Page / Topic Template so all the other topics associated will follow suit.
Cheers... Rick
I tried doing both ways that Captiv8r said above and neither fixed the problem for me with image maps pop-ups.
Like eNerd, I did try to amend a Master Page and have that change apply to all topics associated with the Master Page. I did not receive a prompt to apply the changes.
And, alas, the breadcrumbs continue to display.
Can I make a change to the Master Page, display topics in the Topic Pod and apply the Master Page to the existing topics?
Until I can find a relatively easy way to make this change, I turned off the "Apply Breadcrumbs" option in my file generation logic. I can live without breadcrumbs, but not without the pop-ups. 🙂
Let's see if I can put a finer point on it.
In our case we didn't "implement" breadcrumbs - when migrating from RoboHelp X5 to RoboHelp 8, Adobe (like Bill Gates, who is always trying to "help us, too"), assumed we wanted breadcrumbs. So any instructions about 'undoing what we did' are pointless and irritating.
Now that Adobe has foisted the breadcrumb on us, the user community likes it - on the primary topics at any rate. The functionality on popups is annoying and doesn't produce a logical result (for us anyway).
Beginning in the dim and distant past, our project used the basic unadorned and unmodified Master layout for topics and a different modified-by-us layout for pop-ups. When I look at our pop-up topic layout in RH8 I don't see anything to modify to remove the breadcrumb, therefore I assume that the popup is inheriting (GROAN) from the master.
If I understand correctly, to fix the problem we will have to:
Correct?
-bb
Hi there
Why so argumentative? As near as I can tell this is your first post in this thread. If that's the case, why are you assuming someone would tell you to "undo what you did"?
While it may irritate you that Breadcrumbs are enabled by default unless you specifically turn them off, at least they do offer you an option to disable them if you dislike them.
I'm going to copy/paste your steps so that I might comment inline.
Cheers... Rick
I will assume you're using RH8 since Breadcrumbs are new in RH8.
I have a similar problem - see http://forums.adobe.com/message/2160584
Also, I've tried using a new Master Page for all the pop-up topics and no luck. I've tried turning off all breadcrumbs and it's like something is still lingering from breadcrumbs because my pop-ups don't display correctly then either (for my image maps). I've even tried putting in a breadcrumbs placeholder in the master page and then conditionally building that to leave it out - and that doesn't work either. Looks like this breadcrumbs feature is interfering with all pop-ups.
Hi there
Breadcrumbs were introduced in RoboHelp HTML version 7.
Cheers... Rick
I have the same problem. We implemented breadcrumbs in RH7 and were thrilled with them. In RH7, popups did not display breadcrumbs, which seems entirely reasonable.
Now that we've switched to RH8, breadcrumbs are displayed in all of our popups. Rick, I really do appreciate the helpful information here, but the last line of your post ("it may take you all of 30 seconds") is very glib and seriously incorrect -- at least in my situation and probably in other people's too. We have dozens of help systems to maintain, and many, many thousands of files. Just opening up each system and making one change takes awhile. Next, you cheerfully assume that when I look at the list of topics, I'll immediately recognize which ones are popups. Guess what? I won't! It's going to take awhile. I'll probably just disable popups because our small doc group really doesn't have the bandwidth.
The thing that's annoying is that it worked so beautifully before. I can't imagine that breadcrumbs from popups would ever be useful to anyone, but I could be wrong (maybe people requested it and that's why they're displayed now -- I don't know). But there should be a global option to display or not display them in popups.
In Robohelp 8, breadcrumbs are the default.
To remove breadcrumbs:
1) click Pods - Single Source Layouts.
2) Then in that pod select the layout you are using such as WebHelp. Right click and choose Properties.
3) Click "Next" at the bottom of the Properties pop-up
4) on that next page, UNCHECK the "Add Breadcrumbs Link".
5) Generate your Primary Layout again and the breadcrumbs will be gone. Voila!
Kiss888
That will turn off ALL bookmarks except those specified in a master page. I believe M Boyd only wanted to turn them off in popups if that could be done easily.
M Boyd
Rick had no way of knowing that you could not easily identify your popups. There is a way but I will readily accept it might not suit. However, we can only suggest things, it is for you to decide how viable they are using your knowledge of your project.
The format for a popup is
<a href="javascript:BSSCPopup('New_Topic.htm');" id="a1">topic</a>
A tool like FAR from http://www.helpware.net can be configured to search on <a href="javascript:BSSCPopup and capture the rest of the link. That would give you a list of your popup topics so that you could select all others and associate them with a master page with breadcrumbs. There is a wrinkle in that a topic can be a topic in its own right and be a popup. It's how you call a topic that makes it a popup from that call.
It won't be quick so it all depends on how much you want to get things working your preferred way.
