Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Hibernate Destination
Avatar
Former Community Member
Does anyone know of any tutorials about using hibernate with
Flex 2.0? After trying (unsuccessfully) to figure out how to call
to remote objects on the intergrated JRun server that use hibernate
to persist, I found in the Flex documentation that you can create a
hibernate destination. The documentation show an example, however,
I am fairly new to Flex and hibernate and I need a little more. :)
Any help will be greatly appreciated.
Avatar
I wonder if the hibernate adapter is even included? I digged
in the directory:
C:\fds2\jrun4\servers\default\samples\WEB-INF\lib
cfdataservicesadapter.jar
cfgatewayadapter.jar
These are the only adapters I see. Where is the hibernate
adapter jar?
Avatar
Level 2
> Where is the hibernate adapter jar?
The hibernate adapter is not a separate jar file but is
included with the core FDS jars.
The hibernate jars themselves are not included in the web
applications by default. However, you'll find the jars files at
<install_dir>/resources/hibernate.
In the shipping product, the hibernate assembler will ship as
an example java assembler. You'll find this located at
<install_dir>/resources/samples/assemblers/src.zip
Avatar
me too
and i want to know how it works in eclipse .
anyone can help?
Avatar
Level 3
I use hibernate with spring. Works great. One of the reasons
I went this route is because from the documentation it looks as
though you can only retrieve data using the Flex hibernate adapter.
There are some other advatages to using spring with hibernate. Also
I use MyEclipse IDE (www.myeclipseide.com). It has a number of
add-on's inlcuding a tool that will generate your hibernate classes
from your database, just select the tables/views, and
generate.
