SOLVED
Preserve Headings!
Avatar
Level 1
Hi All,
I am using Acrobat Pro. Extended (V.9).
I would like to allow the headings to appear on each page. But I don't know how to accomplish using LiveCycle.
Anyone please advice?
Kenny
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
You add title text and images to a master page and content pages use the master page.
Steve
Avatar
Correct answer by
Steve
Avatar
Level 1
Steve,
Thanks a lot.
May I have one more question?
If I have two headings, page 1 - 3 will apply heading1, and page 4-6 will apply heading2.
Would you mind please let me know how to implement?
Kenny
Avatar
You're welcome. Create a second Master page and point each page at the applicable content area.
Steve
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
