I'm currently unable to set breakpoints in Flash Builder 4.01. When I try to set one, I get a Null Pointer Exception with the following stack trace:
java.lang.NullPointerException
at com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.findSourceFiles(FlexLineBreakpoint.java:412)
at com.adobe.flexbuilder.debug.breakpoints.FlexLineBreakpoint.instantiate(FlexLineBreakpoint.java:465)
at com.adobe.flexbuilder.debug.model.FlexDebugTarget.instantiateBreakpoint(FlexDebugTarget.java:1012)
at com.adobe.flexbuilder.debug.model.FlexDebugTarget.access$4(FlexDebugTarget.java:1006)
at com.adobe.flexbuilder.debug.model.FlexDebugTarget$1.run(FlexDebugTarget.java:1054)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Has anyone seen an error like this?
Is there a release SWF being loaded at any point?
Ensure:
1. Your SWF is a debug version.
2. Any SWF it loads via a SWFLoader, ModuleLoader or Loader is a debug one.
3. If using RSLs, make sure "Use Local Debug RSLs" are checked in Project Properties -> Flex Build path
