0 Replies Latest reply: Dec 15, 2010 9:30 AM by Deep Woods RSS
    PSE 8 does not recognize new printer profiles.
    Deep Woods Community Member
      I'm using a Windows Vista with PSE 8 and an Epson R1800 Printer.
      From Epson's website I downloaded and installed 4 groups of updated ICC profiles one each for glossy, matte, fine art and canvas. The installation was successful as I can see the new canvas profiles in the spool folder when I go through the computer's control panel. These canvas profiles did not come orininally with the printer so I know they're new.
      Problem is, when I go to Photoshop and access the Epson printer driver there, the new profiles do not show up, only the original profiles. Just to be clear here is the route I took.
      1. After installing the new profiles I rebooted the computer - opened PSE - loaded a picture - and clicked File > Print.
      2. I selected the correct printer - Change Settings - Paper Type. The new ICC profiles do not appear there.
      3. I than go to Advanced Settings and the new profiles don't appear in the drop down window there.
      4. There is one way I can see the new profiles. I click the Advanced button - ICM - add a checkmark to Show all profiles - open the drop down window for Imput Profiles. In there I can see the new profiles, but tech support at Epson said PSE will not manage the colours if I do it this way. I should be able to see the new profiles in the same way I see the original profiles when selecting paper type.
      If this is true, is there a way I can manually load the new profiles into a PSE? I tried this on another computer using CS and the same problem is occuring. The profiles are successfully installed, but not showing up in CS.
      Thank you for your patience.
      Deep Woods
