I am using Captivate v4 but would be also interested if this is also possible in v3 and v5.
Is it possible to enable the learner to click on a button/image on a slide to launch a document direct from within the CBT and then read/save/print the document, be it a .doc or PDF etc ?
Noel (in hope)
Hi Noel
You should be able to do that. Just program a Button or Click Box to open the file name of the document. For example: MyExLife.PDF or TrainWreck.DOC. As long as the document can be found the user should see a prompt to open or save the document.
Cheers... Rick
Helpful and Handy Links Begin learning Captivate 5 moments from now! $29.95 Captivate Wish Form/Bug Reporting Form |
