1. Re: "Paste into" seems broken in CS5 7.0.3
P Spier Dec 16, 2010 10:05 AM (in response to 3ABNPublishing)I'm not seeing this difference here. Are you on Windows or Mac?
Have you tried trashing your prefs? see Replace Your Preferences
2. Re: "Paste into" seems broken in CS5 7.0.3
P Spier Dec 16, 2010 10:07 AM (in response to 3ABNPublishing)By the way, I do see a difference in behavior with paste into when you copy instead of cut the object to paste, but he behavior appears to be the same in CS4 and CS5.
3. Re: "Paste into" seems broken in CS5 7.0.3
3ABNPublishing Dec 16, 2010 10:28 AM (in response to P Spier)I'm using a Mac.
4. Re: "Paste into" seems broken in CS5 7.0.3
P Spier Dec 16, 2010 4:37 PM (in response to 3ABNPublishing)I'm on Windows, so it's possible there's a platform specific bug, but unlikely. Did you trash the prefs?
5. Re: "Paste into" seems broken in CS5 7.0.3
3ABNPublishing Dec 19, 2010 1:58 PM (in response to P Spier)On further testing, the problem seems to be document-specific. It has happened to me more than once, and happened persistently in the case that occasioned starting this thread. However, when I created a new, simple document just now, and tested it in InDesign CS4 and CS5 on the Mac, the results were the same whether I did copy and paste into, or cut and paste into. The object remained in the same relative position on the page spread, which is what I wanted.
Something seems to be causing an issue in the particular document I am working on.
I have not tried trashing the prefs yet, because it is a big pain to recreate them. And now that it seems to be a document-specific problem (bug?), I am not sure that trashing the prefs would help.
6. Re: "Paste into" seems broken in CS5 7.0.3
P Spier Dec 19, 2010 2:07 PM (in response to 3ABNPublishing)See Remove minor corruption by exporting for a pssible fix for the file.
As far as the prefs go, I stongly advise everyone to make a backup set so they can replace them easily without losing anything. See Replace Your Preferences for the locations of the files that need to be backed up. Obviousl;y there is not point, however, in backing up a set of prefs that is possibly corrupt, so do it the next time you replace them.
