cpbittner wrote:
> I am new to CF, I need to build an API that is the LMS
API you would use
> between courseware LMS calls and the LMS backend. I know
I can write an API in
> Java, but am wondering if cfml is powerful enough to be
used to write an API
> in? If you, as an expereinced CF developer where told to
write an API for use
> by ColdFusion, what would you do?
Sure, all an API really is is an interface to an application
that's
exposed for use. What specifically do you need to do? If CF
itself can
do what you need to do, then you can most certainly write an
API in CF
to allow for interaction with the application.
Matt
Matt Woodward
mpwoodward@gmail.com
Adobe Community Expert - ColdFusion
