Can somebody assist me in understanding what's involved in changing Project Set-Up from Webhelp Pro (default) to HTML Help (primary layout).
My project is complete and I would like to Auto-synchronize the TOC.
Any help with this matter is appreciated.
Bob
Not quite sure what you're asking - to change output options, I just right-click on the choice and do "Generate" or "Properties" and then generate.
Jeff,
Adobe Tech Support (India) explained to me that WebHelp Pro is default but couldn't help me to change output to HTML Help (Primary Layout) in order to Auto-synchronize TOC. Suggested of course I try Adobe Forum for answer.
I've developed four similar projects based on HTML Help but for some reason one project is defaulted to WebHelp Pro. Don't know how this occurred, but I'm at a loss how to change the Project Set-up to HTML Help so I can Auto-synchronize TOC option?
I tried your approach, but with no success. That is, right-clicking on HTML Help (Single Source Layouts) Properties and generating, however the Project Set-up (Windows>Window Properties) (WebHelp Pro) remains as default?
What am I missing? Any ideas.
Bob
Hi Bob
If you have a project that is currently configured with WebHelp Pro as the primary layout and you want Micrsoft HTML Help instead, just right-click the layout in the SSL pod and choose "Set as primary layout".
Not following you on the TOC synchronization bit. Perhaps if you restate the issue we might offer suggestions.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Hi Rick,
Set as Primary Layout in Micrsoft HTML Help is grayed out. So instead, right clicked and created a "New Micrsoft HTML Help Layout" then set as Primary Layout and generated project. No luck! Within (Project Set-up) Window Properties> project/name window still displays (WebHelp Pro).
From the start of the project, I never configured WebHelp Pro as the primary layout. Now I can't seem to change the layout to Micrsoft HTML Help so I can enable Auto-synchronization TOC option.
Back in October you helped me with Auto-synchronization TOC option for a project I developed.
http://screencast.com/t/NGQ4MjliY
A far as I know, this option is only available in Micrsoft HTML Help of course but not in WebHelp Pro?
Any help you can offer me to remedy this problem is appreciated.
Bob
Created "New Window" in Project Set-up which enabled Microsoft HTML Help (Primary Layout) setting.
Thanks all.
Cheers!
