1 2 3 4 5 Previous Next 305 Replies Latest reply on Nov 24, 2016 11:05 AM by RobinCostaRica Go to original post
      • 80. Re: Photoshop CS5 Clipboard Issue
        adobeunknownuser
        Hi!
        There is a problem with all curently versions.
        I have an answer from NIK:
        "We know about that issue and are currently working on a solution together with Adobe, which might take some time"
        • 81. Re: Photoshop CS5 Clipboard Issue
          nbreslow
          I just wanted to add my name to the list of people with this exact same problem.  I have a few Nik plugins installed with PS CS5 64bit and the clipboard has been rendered unuseable by them.  Disabling SelectivePalette.8li with a tilde worked for me - let's hope they fix this soon.
          -NB
          • 82. Re: Photoshop CS5 Clipboard Issue
            kslager Level 1
            Had this problem for months and eventually had to switch to 32-bit Photoshop CS5.  After reading this thread, I uninstalled Nik HDR Efex Pro and copy/paste functionality has been fully restored in 64-bit Photoshop CS5.
            • 83. Re: Photoshop CS5 Clipboard Issue
              nycreate Level 1
              I also suffered from the PS CS5 clipboard issue and it drove me crazy, after reading about the NIK software plugins I uninstalled a demo of VIVEZA 2 I had and now clipboard working perfectly. Prob not everyone solution but worked for me... Maybe other 3rd party 64bit plugins could be causing the same issue?
              • 84. Re: Photoshop CS5 Clipboard Issue
                Josh Haftel Level 1
                Hi there from Nik Software! We have identified and resolved the issue. It requires a replacement of a config file so the easiest thing would be if you could contact our support team and then they can walk you through the process. This is only necessary if you're on CS5 (the issue shouldn't occur on CS4 or earlier). You can reach our support team from the following page:
                http://www.niksoftware.com/support/usa/entry.php?view=onlinesupport/usa_form.tpl&language= us
                We're working with Adobe to prevent this type of thing from happening in the future.
                Cheers!
                -Josh
                Sr. Product Manager
                Nik Software, Inc.
                • 85. Re: Photoshop CS5 Clipboard Issue
                  WickSmith Level 1
                  There is an FAQ on the Nik site that asks if you have a problem with HDR Effecx and
                  indicates a configuration file in zip format. However, the FAQ doesn't specify which
                  problem the configuration file is supposed to remedy.
                  Is this the configuration file that solves the clipboard issue?
                  -wick
                  • 86. Re: Photoshop CS5 Clipboard Issue
                    Josh Haftel Level 1
                    No, that solves a different issue entirely. As I mentioned, the best way if you're having this problem is to contact our support team directly with the link I originally posted.
                    -Josh
                    • 87. Re: Photoshop CS5 Clipboard Issue
                      WickSmith Level 1
                      I'll do that, but you should know that your support site indicates that no one from your team will be available to help in the next two days, due to high volume etc. etc. The link you provided just leads to a general support ticket entry form. Is this what you intended?
                      Isn't there some written instruction you could give to all of us who have this problem?
                      -wick
                      • 88. Re: Photoshop CS5 Clipboard Issue
                        Josh Haftel Level 1
                        Well, posting something to our web page will most likely take longer than 2 days which is why I recommended to go through our support staff. Seems like it's pretty urgent though, so let's see if I can't take a crack at this:
                        Download the following file:
                        http://dl.dropbox.com/u/794472/SelToolInst.cfg
                        And place it in the c:\programs\adobe\adobe photoshop cs5\plug-ins\nik software\selective tool\ folder
                        Restart Photoshop
                        Give it a whirl.
                        -Josh
                        • 89. Re: Photoshop CS5 Clipboard Issue
                          Yammer Level 4
                          Yes, that fixed the problem here. Thanks for speeding things up.
                          I copied it to the 64-bit and the x86 counterpart folder too (not sure if the latter was necessary, but it didn't seem to do any harm).
                          • 90. Re: Photoshop CS5 Clipboard Issue
                            WickSmith Level 1
                            Thanks for the config file. I will give it a try.
                            Sorry to imply it was urgent. I could have waited the several days. It's just
                            that the link you supplied does in fact seem to be the Web interface for
                            support, and the reply I received from following that link and filling out the
                            form resulted in an email telling me that "due to the overwhelming popularity of
                            HDR Efex Pro, our response time is now 2-3 business days." It's not a problem.
                            It just seemed as though you were pointing us to a solution or a direct
                            connection to the support team rather than a support ticket application.
                            Again. thanks for the pointer to a solution. I will let you know how it works
                            out.
                            -wick
                            • 91. Re: Photoshop CS5 Clipboard Issue
                              WickSmith Level 1
                              Tried it and it didn't work for me.
                              I placed the file in the following directory, which is close as I could get to
                              the one you specified. My programs are stored on my F: drive:
                              F:\Program Files\Adobe Photoshop CS5 (64 Bit)\Plug-ins\Nik Software\Selective
                              Tool
                              Is this wrong? It didn't seem to work. Clipboard still not working in CS5
                              64-bit.
                              -wick
                              • 92. Re: Photoshop CS5 Clipboard Issue
                                LittleLew
                                Worked for me.
                                Can access clipboard and Silver Efex seems to work fine.
                                Care to tell us what the issue is/was?
                                Lew
                                • 93. Re: Photoshop CS5 Clipboard Issue
                                  LittleLew Level 1
                                  Worked for me.
                                  Lew
                                  • 94. Re: Photoshop CS5 Clipboard Issue
                                    nickpudar Level 1
                                    Sorry, but that solution did not work for me.  I'm still having the Clipboard issue.  I wish it worked!
                                    Nick
                                    • 95. Re: Photoshop CS5 Clipboard Issue
                                      Josh Haftel Level 1
                                      Strange, it seems to work for some and not others. Once we were able to reproduce this on our test machines, this fix seemed to work. I'll have to get back to the dev & qa teams to see if they have any further thoughts. I might need to get a hold of you directly, could you send me a private message with your contact info in case we need to dig deeper?
                                      -Josh
                                      • 96. Re: Photoshop CS5 Clipboard Issue
                                        JanGeloen
                                        I have only Alien Skin Plugin's and I hve the clipboard issue... I wish this would get solved, it seems like adobe knows where the problem lies. Please fix this problem..
                                        • 97. Re: Photoshop CS5 Clipboard Issue
                                          laserfaire Level 1
                                          This problem with the Clipboard was driving me crazy.  I uninstalled Nik HDR EffectS Pro and it went away.  Yoo-hah.
                                          • 98. Re: Photoshop CS5 Clipboard Issue
                                            nbreslow Level 1
                                            Hi Josh,
                                            The file you posted fixed the issue for me.
                                            Does NIK plans to correct this in future updates.  I am wondering if I am going to need i to manually install this file every time I upgrade or reinstall a NIK product.
                                            -NB
                                            • 99. Re: Photoshop CS5 Clipboard Issue
                                              WickSmith Level 1
                                              Josh, just tried to send you a private message, but this system apparently doesn'tmake that possible. I went to your profile page and clicked on "send private message" but it didn't recognize you as a valid email recipient.
                                              Checked on my own profile page here and there is an email address there, so you can contact me.
                                              -wick
                                              • 100. Re: Photoshop CS5 Clipboard Issue
                                                ClintSteed
                                                Hi Josh,
                                                However I did have to install it both the "Program Files" and "Program Files (x86)" directory path you posted. I'm Woking on a Win 7 64x sytem and have both PS CS5 32x and 64x version installed.
                                                Belay my last. I rebooted and the clipboard in PS CS5 64X no longer works. No problem with CS5 32x or CS4 64x.
                                                • 101. Re: Photoshop CS5 Clipboard Issue
                                                  jordancameron
                                                  I had the exact same problem on my one year old Acer Aspire 5738-6745 laptop running Windows 7 Home Premium 64-bit and Adobe Photoshop CS5 Extended 64-bit.
                                                  The weird thing is, it only happened to me after I reinstalled windows. It never occurred before.
                                                  Anyways, I found a solution. You just have to open Notepad and type in the following:
                                                  Windows Registry Editor Version 5.00
                                                  [HKEY_CURRENT_USER\Software\Adobe\Photoshop\12.0]
                                                  “AlwaysImportClipboard”=dword:00000001
                                                  Then save it as AlwaysImportClipbd_ON.reg, close Photoshop if it is opened, and install the registry file.
                                                  Doing this worked for me!
                                                  Hope it helps!
                                                  -Jordan
                                                  • 102. Re: Photoshop CS5 Clipboard Issue
                                                    JanGeloen Level 1
                                                    this is not working for me..
                                                    Still having this issue (alien skin plugins installed)
                                                    • 103. Re: Photoshop CS5 Clipboard Issue
                                                      jordancameron Level 1
                                                      You should try to uninstall the plugin then.
                                                      All I know is that the plugin is not the initial problem, because I have never had it installed.
                                                      But seriously, using the registry thingy solved the problem for me.
                                                      Sorry I can't help more
                                                      -Jordan
                                                      • 104. Re: Photoshop CS5 Clipboard Issue
                                                        Mr.benttop Level 1
                                                        I've been following this thread with interest. It seems every time I upgrade Photoshop I have to go find this registry hack again. CS2, CS3, CS4 and now CS5. But this time it doesn't do the trick for me either. I'm on Win 7 64 bit, no add ins. I hope Adobe keeps looking because there is a problem that is not related to plug - ins, even though it seems plug - ins seem to help push the problem into the forefront.
                                                        • 105. Re: Photoshop CS5 Clipboard Issue
                                                          Then I should count myself as lucky! Sorry I can't help further.
                                                          I hope this gets solved for all you folks who are still struggling!
                                                          • 106. Re: Photoshop CS5 Clipboard Issue
                                                            SG... Adobe Employee
                                                            The config file suplied by Josh H. at Nik should only impact Nik plug-ins, afaik. We have a bug report open and are still investigating the general plug-in SDK documentation. From Nik's findings, one case that can cause problems is triggered by calls made by 3rd party plug-ins, following a sample plug-in from Adobe.
                                                            I'm not aware where Alien Skin is at invetigating a fix on their side, but will update here when I hear something.
                                                            It also still isn't clear from the follow-up messages if we might have 2 or more bugs with the same end result of a broken clipboard. From what I've read here, there are 1) users with 3rd party plug-ins that have a problem, which goes away when the plug-ins are disabled, and 2) users without 3rd party plug-ins that have had to result to reg key changes. Is that how others see it? Can those reporting the reg key change as a fix confirm that they aren't running any 3rd party or non-default plug-ins?
                                                            regards,
                                                            steve
                                                            • 107. Re: Photoshop CS5 Clipboard Issue
                                                              Mr.benttop Level 1
                                                              function(){return A.apply(null,[this].concat($A(arguments)))}
                                                              I can report that I'm not running any plug-ins, have tried the registry fix, and still have the problem.
                                                              • 108. Re: Photoshop CS5 Clipboard Issue
        Mr.benttop Level 1
        Well I should know better than this, but what I just posted is incorrect. It seems that after running the registry fix, you MUST reboot! I apparently had forgotten to do this, and once I rebooted this morning my Photoshop CS5 clipboard is working correctly! My apologies to those who may have scurried off to look at things that did not need looking at.
        • 109. Re: Photoshop CS5 Clipboard Issue
        JanGeloen Level 1
        no, even after restart the issue is still there.
        • 110. Re: Photoshop CS5 Clipboard Issue
        Mr.benttop Level 1
        For what it's worth, when I did the registry hack, I first used notepad to create a .reg file. When it was apparent that it did not work, I used regedit to go look, and Windows 7's security configuration here had apparently prevented the .reg file from causing the entry to be recorded. So I created the entry manually in regedit. You might have a peek - maybe your security settings are like mine.
        • 111. Re: Photoshop CS5 Clipboard Issue
        johnvalo Level 1
        I am running Photoshop CS5 with no plugins. I have the problem intermittently. The clipboard works several times, then does not, retaining the previous clipboard entry. Purging does not help. Restarting Photoshop works. I have not tried the registry hack.
        • 112. Re: Photoshop CS5 Clipboard Issue
        Andrew Ochtinsky, Art.com Level 1
        I was definitely having this problem on my machine, and the above registry hack fixed it.
        Windows XP 32-bit
        Core 2 Duo
        Photoshop CS5 12.0 x32
        I have also had the same problem on my Win 7 / i7 / 64 machine. I haven't had a chance to see if the hack works on that environment, but I suspect it isn't environment-specific.
        • 113. Re: Photoshop CS5 Clipboard Issue
        Noel Carboni Level 8
        As far as I can tell, using Windows 7 x64 and Photoshop CS5, there is no limit to the size of the clipboard it will import, whether or not the AlwaysImportClipboard registry value is set or not.
        -Noel
        • 114. Re: Photoshop CS5 Clipboard Issue
        umarmughal
        Everybody is just discussing here but anyone found any solution or not yet?
        • 115. Re: Photoshop CS5 Clipboard Issue
        Read through the thread:
        For newer versions of Photoshop (e.g., CS5) some plug-ins by a particular company were identified as interfering with the clipboard.
        For older versions of Photoshop there's a built-in limit to the size of the clipboard it will import, unless a particular registry value is added.
        -Noel
        • 116. Re: Photoshop CS5 Clipboard Issue
        umarmughal Level 1
        I am using Z800 Workstation, 8 Core machine, with 12GB Ram and everything on top with windows 7 64 bit, i dont feel any built-in limit here, about plugin i am not sure, is there anyway i can fix the issue as you said by adding registyr value, btw i am using CS5 and specilly i cant copy paste from illustrator which i could a week back, this is really weird.
        • 117. Re: Photoshop CS5 Clipboard Issue
        mats_h
        Hope it helps!
        -Jordan
        I'm running CS5 64 on a clean Win 7 64 system. Had problems with the clipboard just as described in this thread. No funky plugins or processes running. Adding the registry entry solved it - however I had to add the registry entry as a QWORD insted of a DWORD, or PS would hang when I attempted pasting.
        Cheers.
        • 118. Re: Photoshop CS5 Clipboard Issue
        gbriney
        I had the clipboard paste problem with CS5 64-Bit while using Color Efex Pro. Removing the filter restored normal clipboard function. Same filter with PSE 9 did not cause the problem as it's 32-bit.
        Download of the config file fix posted by NIK Software wasn't successful at first, though I was successful after getting a tip from Dropbox support to add the ?dl=1 parameter to the url as follows:
        http://dl.dropbox.com/u/794472/SelToolInst.cfg?dl=1
        Copying the cfg file to the Selective Tool folder as described in the NIK Software post 88 solved the problem.
        • 119. Re: Photoshop CS5 Clipboard Issue
        JanGeloen Level 1
        Strangest thing happened today. I installed an extra plugin (knoll light factory) alongside my two already installed ones (alien skin exposure en alien skin blow up) an as by magic the issue is gone... I now can copy and paste as I should.
        No idea how this happened but after i installed it I was curious and tried to paste.
        Either way -> happy!
