39 Replies Latest reply on Dec 23, 2010 1:16 PM by Darren Hall
    New System
    Darren Hall Level 1
      Hi
      I am busy building a new system and have the following in mind please help me on my way.
      Antec P190 with neolink 1200watt
      Asus P6X58D-E
      6 x 4 GB Corsair GT DDR-2000
      I7 980X
      2 x WD 600GB Veloci Raptor (Raid 0 for OS)
      4x 1 TB Seagate Raid 0 for storage will get raid card later
      GTX 480.
      what will I be able to over clock to and what is the best cooling for CPU?
      Is this ram good?
      any other ideas?
        • 1. Re: New System
          wb_martin
          1.2 TB (2 x 600 GB, RAID 0) is a large OS drive, although if you are using it for scratch files too, maybe not.
          You might review Harm's discussion on "To RAID or Not to RAID"
          http://forums.adobe.com/thread/525263
          and learn more about RAID types/configurations, particularly for your planned 4 x 1TB storage array.  I would consider RAID 3, 5 or 6.
          I use a Corsair H70 CPU cooler and am happy with it.
          There's a lot of discussion about whether costly high speed memory is really necessary/valuable, particularly with 24 GB memory on your mobo.  You may look for more expert advice on that issue.  Be sure to check the QVL for the mobo to check memory compatibility.
          Presumably you're planning on Win7-64 bit as the OS.
          Good luck!
          1 person found this helpful
          • 2. Re: New System
            Harm Millaard Level 7
            1. 4.4 GHZ should be reasonably easy. CoolerMaster Hyper 212, Noctua NH-D14, Prolimatech Megahalem, etc.
            2. Yes.
            3. Get a raid controller ASAP. Otherwise you will run into difficulties in getting your data across to a new array, which will be a major obstacle. A 4 disk raid0 entails quite some risks. I would rather go for a single 150+ GB OS/programs disk and a 5 or 6 disk raid5, although your performance will suffer, since ICHR controllers are pretty lousy with parity raids.
            • 3. Re: New System
              Darren Hall Level 1
              I was thinking it would give very good performance becuase of the Raid 0 and that the drives are SATA 3 6G interface, I will raid 0 the 4 drives for storage. I can get Seagate 2TB 64mp cache SATA 3 6gps drives for half the price would this be a option for OS.
              • 4. Re: New System
                Darren Hall Level 1
                Thanks Harm,
                dont you think a SATA3 6gps is better ? the 600 raptor is a SATA3 and the 150 is only SATA 2.
                thanks
                Darren
                • 5. Re: New System
                  There is no way that a single disk will be limited by a SATA2 connector. SATA3 is mostly hype and all about theoretical bandwidth, but in practice it shows no benefits in throughput. The one advantage of some SATA3 drives is the larger cache, 64 MB versus 32 MB, but that is all. Even with large arrays there is no difference in performance between SATA2 and SATA3, because the PCI-e bus is the limiting factor.
                  It is about the same with USB2 and USB3. Theoretically USB3 is way faster, but in practice USB3 disks are only 2-3 times faster than USB2, because of the congestion on the USB bus and the sharing of resources, at least from the reports I have read.
                  • 6. Re: New System
                    Darren Hall Level 1
                    OK great, save me some bucks one disk it is.
                    thanks
                    Harm
                    • 7. Re: New System
                      Darren Hall Level 1
                      Hi Harm,
                      some more advice please. I can get a Intel Big Laurel RS2BL080 8 channel 6G SAS Raid 512MB at a decent price is this ok as I cant find the one you use in South Africa. What HDD do you recomend to use for the raid setup size and make.
                      thanks again
                      Darren
                      • 8. Re: New System
                        Scott Chichelli Level 3
                        i would recommend that card over the areca purely for price/performance.
                        i honestly see no point to the Areca cards over that one
                        Scott
                        ADK
                        • 9. Re: New System
                          Scott,
                          I agree with you for out of the box controllers, but you disregard the capabilities of the Areca to:
                          1. Increase cache memory to 4 Gb, which the Intel can't and this makes a significant difference,
                          2. The ability to add a BBM (battery backup module) to the Areca, and
                          3. The support of Raid3/30 which the Intel does not have.
                          • 10. Re: New System
                            Darren Hall Level 1
                            Harm
                            thanks, I have just checked the wholesalers pricelist and they do have a "smart battery" for the card.  what hard drives do you recommend and what size.
                            thanks
                            Darren
                            • 11. Re: New System
                              I would suggest the WD RE4 (bit costly) or the Samsung F3, both in 1 TB sizes. Another option is the Seagate 7200.12.
                              • 12. Re: New System
                                Darren Hall Level 1
                                thanks Harm
                                • 13. Re: New System
                                  ECBowen Adobe Community Professional & MVP
                                  " 2. The ability to add a BBM (battery backup module) to the Areca"
                                  The Intel card does have the BBM connector as well.
                                  Eric
                                  ADK
                                  • 14. Re: New System
                                    Darren Hall Level 1
                                    Harm, WB Martin, Scott and Eric,
                                    i wanted to purchase one on thursday and now they don't have stock. I start my new build today as I have all the other parts. only the HDD and raid card are missing.
                                    this is what I have got,
                                    Asus P6X58D-E
                                    6 x 4 gig Corsair dominator gt ram ddr3 2000
                                    1 x WD 600 gig Velociraptor (no stock of the 150)
                                    Gigabyte 480 GTX
                                    Corsair H70 water cooler
                                    1  x seagate 1 Tb (had this laying around will use just to get system going)
                                    1 x LG Blu-ray
                                    will get the intal raid card and drives in the next week or two. I can only get seagate 1 Tb 7200.12no stock of samsung and WD
                                    thanks and I will give feed back once machine is completed
                                    Darren
                                    • 15. Re: New System
                                      Darren Hall Level 1
                                      Hi
                                      I have put the machine together and it is great so far. Can any body give me the settings for the asus mobo and 980x to overclock and how to do it.
                                      thanks
                                      Darren
                                      • 16. Re: New System
                                        wb_martin Level 1
                                        Check out these links:
                                        a general guide for overclocking:
                                        http://www.youtube.com/watch?v=_Cu0I2ITDQg&feature=related
                                        and board-specific information here:
                                        http://vip.asus.com/forum/topic.aspx?board_id=1&model=P6X58D-E&SLanguage=en-us
                                        I would suggest routine consult of the latter link.....good luck!
                                        • 18. Re: New System
                                          Darren Hall Level 1
                                          thanks wb-martin, it looks too new for me but I will keep on trying.
                                          thanks
                                          Darren
                                          • 19. Re: New System
                                            Darren Hall Level 1
                                            the machine is up and running,
                                            this is the final spec:
                                            Antec P190 with neo link 1200w
                                            Asus P6X58D-E
                                            24 gig Corsair Dominator GT Ram 2000
                                            Gigabyte GTX 480
                                            600 gig WD Velciraptor for OS Win 7 64 bit ultimate
                                            1 TB seagate for Music and Digtal juice and so on
                                            Intel RS2BL080 Raid Controller
                                            8 x Samsung F3 (well 4 should get the other on Monday)
                                            LG Blu-Ray
                                            few extra Fans
                                            4 drives are in a Coolermaster 3 to 4 cage with fan.
                                            any suggestions on the raid setup would be appreciated.
                                            Darren
                                            • 20. Re: New System
                                              Darren,
                                              I suggest either an 8-disk raid5 or raid6 or a 7-disk raid5 with one hot-spare.
                                              • 21. Re: New System
                                                Darren Hall Level 1
                                                thanks Harm
                                                • 22. Re: New System
                                                  Jay Knobbe
                                                  wb martin...
                                                  how do you like the h70 cooler?
                                                  I looked at the h50 and h70. Some reviews said the h50 wasn't much improvment over stock and the h70 had lots of fan noise, etc.
                                                  What has your experience been?
                                                  • 23. Re: New System
                                                    wb_martin Level 1
                                                    Hi Jay,
                                                    So far, I like the H70 cooler.  When I have monitored/checked temperatures, the CPU olds at 26 deg. C., and is pretty stable at that temperature, but I am not overclocking yet which is sure to put a thermal load on the processor and the ASUS Rampage III Formula mobo with 24GB onboard in general.
                                                    I built the system in the CoolerMaster HAF-X case, and I added an extra 120mm fan to the top of the case for improved airflow.   I am only using one graphics adapter - the superclocked eVGA GeForce 470 and I haven't optimized the system fan speeds yet, so I haven't optimized system noise yet - that's all forthcoming.
                                                    Overall, I am happy with the H70.  It has a small footprint in size - I haven't had problems with space issues inside the HAF-X as some people have reported.
                                                    Hope this helps.  Good luck!
                                                    Bill
                                                    • 24. Re: New System
                                                      Darren Hall Level 1
                                                      I have the Corsair H70, the problem I had was the side fan on the Antec 190 would not fit so I mounted it on the outside. my temps are not so low but our ambient temps in South Africa are alot higher today we went to 36 celcius.
                                                      Darren
                                                      • 25. Re: New System
                                                        wb_martin Level 1
                                                        Hi Darren,
                                                        That's a little bit toasty, but it is your summer in the southern hemisphere, right?  I suspect the best you can hope for with fan-assisted liquid cooling radiators is ambient temp, right?  36 should be OK though.
                                                        The side fan on the HAF-X is located lower on the case - over the graphics card region of the mobo, so I don't have the problem of it obstructing the CPU cooler; however, I was REALLY reluctant to stay with the tall CPU cooler assembly that shipped with the i7-980X - it just seemed too monstrous!  I do worry about my ICH and IOH temps though - they run about 46 and 48 deg. C, respectively; however, I don't know what they're supposed to run at.
                                                        Bill
                                                        • 26. Re: New System
                                                          Darren Hall Level 1
                                                          Hi Bill,
                                                          Yes summer it is and what a summer it is hot as hell and then it rains like hell. some days my xeon machine battles to work it gets so hot. I will start to overclock next week and try and find a good working point.
                                                          regards
                                                          Darren
                                                          • 27. Re: New System
                                                            Darren Hall Level 1
                                                            Hi Harm,
                                                            can you help me with the following:
                                                            I have 8 1tb Samsung F3 with a Intel RS2BL080 raid card with 512mb cache
                                                            I am going with the following Raid 5 = 6.36gb (I think this leaves one drive spare)
                                                            what would be the best settings for the following?
                                                            Strip size: 8kb 16kb 32 kb 64kb 128kb 256kb 512 or 1mb
                                                            Acecess Policy: RW, Read only or blocked
                                                            Write Policy:Write through, always write back or write back with BBU
                                                            IO Policy: Direct or cached
                                                            Drive Cache: No change, Enable or disable
                                                            Disable BGI: No or Yes
                                                            I can select size for disc (R5 = 6.36TB R6 = 5.451TB R0 = 7.268 R1 = 3.634)
                                                            thanks in advance
                                                            Darren
                                                            • 28. Re: New System
                                                              Stripe size leave default for raid selected.
                                                              Select Raid 5 or Raid 6. Raid 6 is one more level of parity over raid 5 which means you can have 2 drives fail and your raid is held together by the parity. If the 3rd drive fails then the raid is gone. This also takes the equivalent of another drive from the raid volume size so you will sacrifice more space.
                                                              Access Policy - RW
                                                              Write Policy - Always Write Back
                                                              I/O - Cached
                                                              Drive Cache - Enabled
                                                              Leave BGI
                                                              Eric
                                                              ADK
                                                              • 29. Re: New System
        Darren Hall Level 1
        thanks Eric
        • 30. Re: New System
        Darren Hall Level 1
        Hi Eric,
        these are the settings I used:
        Strip Size 256KB
        Read pol No read ahead
        write pol always write back
        IO pol cached IO
        Access RW
        Disc Cache enabled
        test: long bench 32mb, it looks a little erattic to me
        • 31. Re: New System
        Read ahead should be set to adaptive. That will help some with the fluctuations
        The reasons you see the dips and so forth have to do with how Sata drives drop in performance once the capacity exceeds 50%. At 60% the lost performance becomes very significant and at 75 % the performance drops like a rock. The Higher End raid controllers like the Intel and Areca cards attempt to minimize this with cached instructions i/e why Harm always pushes people to get the extra cache on their controllers. The other side to the fluctuations is the parity. In a raid 0 you won't see near the fluctuations. It will normally look relatively flat over the array. A parity raid however fluctuates more due to the extra overhead for the parity.Now the controllers on the drives will also effect the fluctuations so an array of 1 model drive may fluctuate differently than another model array. Your readout looks normal and the low spots are likely the end of drives where the speed is normally slowest on SATA drives. This is why SCSI drives were so predominant back several years ago. They did not have the same performance drops that SATA drives do as the volume capacity is filled. SSD Drives have taken that spot in today's market.
        Eric
        ADK
        • 32. Re: New System
        Darren Hall Level 1
        thanks Eric,
        I did the ppbm5 benchmark last night and it if I am reading the results correctly my new machine with 8 drives with raid contoller is slower than my old machine that had 4 drives raid 0 using the onboard intel raid controller. +- 150 sec slower on the disc test. i am going to test some more before I post the results,
        thanks for the help and I will keep you posted
        regards
        Darren
        • 33. Re: New System
        Without knowing the configuration of the old machine and the new machine, I couldn't point to anything.
        Eric
        ADK
        • 34. Re: New System
        Darren Hall Level 1
        Hi Eric
        thanks, I will send you the results when I have tested some more. On the ppbm5 results page my old machine was called Axco Productions.
        Dual Quad Core intel xeon 2.33
        16 gig 677 ecc ram
        Intle S5000XVN Mobo
        1 x 1 tb seagate OS Win 7 64
        1 x 1 tb cache files music digital juice
        4 x 1 tb seagates raid0 (internal raid) project files
        Darren
        • 35. Re: New System
        Ya something is not setup right on the new system. There is no way the old Xeon system should bench better than the new one.
        Eric
        ADK
        • 36. Re: New System
        Darren,
        With 8 x F3's in Raid5 on the Intel controller your AVI test would likely be around 75 - 90 seconds if things are properly setup. Have you tried HDTach or Atto to see what your transfer rates are?
        • 37. Re: New System
        Darren Hall Level 1
        Hi Harm,
        yes I did. I just set the raid to raid 0 and got 802mb and raid 5 was +- 640
        Darren
        • 38. Re: New System
        The AVI test with 8 WD drives in raid 5 was in the 60's in testing here and that was with 5.0.1. It was the same as 2 raid 0 arrays on that raid controller.
        Eric
        ADK
        • 39. Re: New System
        Darren Hall Level 1
        Hi All,
        I have just had Eric from ADK  help me with my machine "online' and we found the problem "MATROX MINI MAX"  the speed of the disck test was increased from 516 sec to180 sec and no waiting for media encoder to change settings. I would like to thank Eric for the fantastic help and everybody who commented.
        the machine will go for tweaking and I will then benchmark and post results. I am sure it will be top 10.
        thank you all
        Darren
