or: why doesn't a switch case without a break work always?
I have got this code snippet as part of a function defined in MyClass
var ni:int, np:int, xv:Number, yv:Number;
for(ni = np = 0 ; ni < cdata.cmds.length ; ni++)
{ switch(cdata.cmds[ni])
{ case GraphicsPathCommand.MOVE_TO:
/* A: code here to setup a new path*/
var b:MyPath = new MyPath();
/* B: duplicate switch case
xv = cdata.path[np++];
yv = cdata.path[np++];
b.add(xv, yv);
break;
// fall through
case GraphicsPathCommand.LINE_TO:
b.add(xv, yv);
break;
case GraphicsPathCommand.CURVE_TO:
b.add(xv, yv, true);
b.add(xv, yv);
break;
the code worked well until I changed the the definition of MyPath and consequently had to change code in the A section.
This produced the - not very enlightening - error message (which suggests to send the error to Adobe but does not give a link)
The script would work again after I enabled the B section
copy and paste your complete error message.
it is a bit lengthy, though
verify PlotText/bezigon()
stack:
scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ Material$ PlotObjekt$ PlotText$]
locals: PlotText * * * * * * * * * * * * * *
0:debugfile "/home/wolfgang/Plotservice;;PlotText.as"
stack:
2:debugline 273
stack:
5:getlocal0
stack: PlotText
6:pushscope
stack:
scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ Material$ PlotObjekt$ PlotText$] PlotText
7:pushnull
stack: null
8:coerce Letter
stack: Letter?
10:setlocal 4
stack:
locals: PlotText * * * Letter? * * * * * * * * * *
12:pushnull
stack: null
13:coerce PlotTextFormat
stack: PlotTextFormat?
15:setlocal 5
stack:
locals: PlotText * * * Letter? PlotTextFormat? * * * * * * * * *
17:pushnull
stack: null
18:coerce FontOutlines
stack: FontOutlines?
21:setlocal 6
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? * * * * * * * *
23:pushnull
stack: null
24:coerce flash.geom::Matrix
stack: flash.geom::Matrix?
26:setlocal 7
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? * * * * * * *
28:pushnan
stack: Number
29:setlocal 8
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number * * * * * *
31:pushnull
stack: null
32:coerce Object
stack: Object?
34:setlocal 9
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? * * * * *
36:pushbyte 0
stack: int
38:setlocal 10
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int * * * *
40:pushbyte 0
stack: int
42:setlocal 11
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int * * *
44:pushnan
stack: Number
45:setlocal 12
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number * *
47:pushnan
stack: Number
48:setlocal 13
stack:
locals: PlotText * * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
50:debug
stack:
56:debug
stack:
62:debug
stack:
68:debugline 275
stack:
71:newarray 0
stack: Array
73:coerce Array
stack: Array
76:setlocal1
stack:
locals: PlotText Array * * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
77:debugline 276
stack:
80:findpropstrict Bezigon
stack: global
83:constructprop 150 0
stack: Bezigon
87:coerce Bezigon
stack: Bezigon
90:setlocal2
stack:
locals: PlotText Array Bezigon * Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
91:debugline 277
stack:
94:getlocal1
stack: Array
95:getlocal2
stack: Array Bezigon
96:callproperty http://adobe.com/AS3/2006/builtin::push 1
stack: uint
100:pop
stack:
101:debugline 278
stack:
104:pushbyte 0
stack: int
106:convert_i
stack: int
107:setlocal3
stack:
locals: PlotText Array Bezigon int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
108:jump 860
B0:
stack:
locals: PlotText? Array? Bezigon? int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
112:label
stack:
113:debug
stack:
120:debug
stack:
127:debug
stack:
133:debug
stack:
139:debug
stack:
146:debug
stack:
153:debug
stack:
160:debug
stack:
167:debug
stack:
174:debug
stack:
181:debugline 279
stack:
184:getlocal0
stack: PlotText?
185:getproperty PlotText::letters
stack: Array?
187:getlocal3
stack: Array? int
188:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
190:coerce Letter
stack: Letter?
192:setlocal 4
stack:
194:debugline 280
stack:
197:getlocal 4
stack: Letter?
199:callproperty getPlotTextFormat 0
203:coerce PlotTextFormat
205:setlocal 5
stack:
207:debugline 281
stack:
210:findpropstrict FontManager
stack: global
213:getproperty FontManager
stack: FontManager$?
216:getlocal 5
stack: FontManager$? PlotTextFormat?
218:getproperty font
stack: FontManager$? String?
220:getlocal 5
stack: FontManager$? String? PlotTextFormat?
222:getproperty bold
stack: FontManager$? String? Object?
224:getlocal 5
stack: FontManager$? String? Object? PlotTextFormat?
226:getproperty italic
stack: FontManager$? String? Object? Object?
228:callproperty getOutlineFont 3
232:coerce FontOutlines
235:setlocal 6
stack:
237:debugline 283
stack:
240:getlocal 4
stack: Letter?
242:getproperty transform
stack: flash.geom::Transform?
244:getproperty matrix
246:coerce flash.geom::Matrix
248:setlocal 7
stack:
250:debugline 284
stack:
253:findpropstrict Number
stack: global
255:getlocal 5
stack: global PlotTextFormat?
257:getproperty size
stack: global Object?
259:callproperty Number 1
stack: *
262:pushshort 1024
stack: * int
265:divide
stack: Number
266:convert_d
stack: Number
267:setlocal 8
stack:
269:debugline 285
stack:
272:getlocal 7
274:getlocal 7
stack: flash.geom::Matrix? flash.geom::Matrix?
276:getproperty a
stack: flash.geom::Matrix? Number
279:getlocal 8
stack: flash.geom::Matrix? Number Number
281:multiply
282:setproperty a
stack:
285:getlocal 7
287:getlocal 7
289:getproperty b
292:getlocal 8
294:multiply
295:setproperty b
stack:
298:getlocal 7
300:getlocal 7
302:getproperty c
305:getlocal 8
307:multiply
308:setproperty c
stack:
311:getlocal 7
313:getlocal 7
315:getproperty d
318:getlocal 8
320:multiply
321:setproperty d
stack:
324:debugline 286
stack:
327:getlocal 7
329:getlocal 7
331:getproperty ty
334:getlocal 4
stack: flash.geom::Matrix? Number Letter?
336:getproperty ht
339:add
340:setproperty ty
stack:
343:debugline 287
stack:
346:findpropstrict trace
stack: global
348:pushstring "text "
stack: global String
351:getlocal 4
stack: global String Letter?
353:getproperty text
stack: global String String?
355:add
356:pushstring " mtx "
359:add
360:getlocal 7
stack: global String flash.geom::Matrix?
362:add
363:callproperty trace 1
stack: void?
366:pop
stack:
367:debugline 288
stack:
370:getlocal 6
372:getlocal 4
stack: FontOutlines? Letter?
374:getproperty text
stack: FontOutlines? String?
376:pushbyte 0
stack: FontOutlines? String? int
378:callproperty http://adobe.com/AS3/2006/builtin::charCodeAt 1
stack: FontOutlines? Number
382:getlocal 7
stack: FontOutlines? Number flash.geom::Matrix?
384:callproperty getOutlineData 2
stack: Object?
388:coerce Object
stack: Object?
390:setlocal 9
stack:
392:debugline 291
stack:
395:pushbyte 0
stack: int
397:dup
stack: int int
398:setlocal 14
stack: int
locals: PlotText? Array? Bezigon? int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number int
400:convert_i
stack: int
401:setlocal 11
stack:
403:getlocal 14
stack: int
405:kill 14
stack: int
407:convert_i
stack: int
408:setlocal 10
stack:
410:jump 788
B1:
stack:
414:label
stack:
415:jump 661
B2:
stack:
419:label
stack:
420:debugline 294
stack:
423:getlocal2
stack: Bezigon?
424:getproperty length
stack: uint
426:convert_b
stack: Boolean
427:iffalse 480
stack:
431:debugline 295
stack:
434:getlocal2
stack: Bezigon?
435:getlocal2
stack: Bezigon? Bezigon?
436:getproperty length
stack: Bezigon? uint
438:pushbyte 1
stack: Bezigon? uint int
440:subtract
stack: Bezigon? Number
441:getlocal2
stack: Bezigon? Number Bezigon?
442:pushbyte 0
stack: Bezigon? Number Bezigon? int
444:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: Bezigon? Number *
446:setproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack:
448:debugline 296
stack:
451:getlocal2
stack: Bezigon?
452:pushtrue
stack: Bezigon? Boolean
453:setproperty closed
stack:
456:debugline 297
stack:
459:findpropstrict Bezigon
stack: global
462:constructprop 150 0
stack: Bezigon
466:coerce Bezigon
stack: Bezigon
469:setlocal2
stack:
locals: PlotText? Array? Bezigon int Letter? PlotTextFormat? FontOutlines? flash.geom::Matrix? Number Object? int int Number Number *
470:debugline 298
stack:
473:getlocal1
stack: Array?
474:getlocal2
stack: Array? Bezigon
475:callproperty http://adobe.com/AS3/2006/builtin::push 1
stack: uint
479:pop
B3:
stack:
scope: [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ Material$ PlotObjekt$ PlotText$] PlotText?
480:label
stack:
481:debugline 306
stack:
484:getlocal 9
stack: Object?
486:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::path
stack: *
489:getlocal 11
stack: * int
491:dup
stack: * int int
492:increment_i
stack: * int int
493:convert_i
stack: * int int
494:setlocal 11
stack: * int
496:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
498:convert_d
stack: Number
499:setlocal 12
stack:
501:debugline 307
stack:
504:getlocal 9
stack: Object?
506:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::path
stack: *
509:getlocal 11
stack: * int
511:dup
stack: * int int
512:increment_i
stack: * int int
513:convert_i
stack: * int int
514:setlocal 11
stack: * int
516:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
518:convert_d
stack: Number
519:setlocal 13
stack:
521:debugline 308
stack:
524:getlocal2
stack: Bezigon?
525:getlocal 12
527:getlocal 13
stack: Bezigon? Number Number
529:callproperty add 2
stack: void?
533:pop
stack:
534:debugline 309
stack:
537:jump 779
B4:
stack:
541:label
stack:
542:debugline 311
stack:
545:getlocal 9
stack: Object?
547:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::path
stack: *
550:getlocal 11
stack: * int
552:dup
stack: * int int
553:increment_i
stack: * int int
554:convert_i
stack: * int int
555:setlocal 11
stack: * int
557:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
559:convert_d
stack: Number
560:setlocal 12
stack:
562:debugline 312
stack:
565:getlocal 9
stack: Object?
567:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::path
stack: *
570:getlocal 11
stack: * int
572:dup
stack: * int int
573:increment_i
stack: * int int
574:convert_i
stack: * int int
575:setlocal 11
stack: * int
577:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
579:convert_d
stack: Number
580:setlocal 13
stack:
582:debugline 313
stack:
585:getlocal2
stack: Bezigon?
586:getlocal 12
588:getlocal 13
590:pushtrue
stack: Bezigon? Number Number Boolean
591:callproperty add 3
stack: void?
595:pop
stack:
596:debugline 314
stack:
599:getlocal 9
stack: Object?
601:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::path
stack: *
604:getlocal 11
stack: * int
606:dup
stack: * int int
607:increment_i
stack: * int int
608:convert_i
stack: * int int
609:setlocal 11
stack: * int
611:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
613:convert_d
stack: Number
614:setlocal 12
stack:
616:debugline 315
stack:
619:getlocal 9
stack: Object?
621:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::path
stack: *
624:getlocal 11
stack: * int
626:dup
stack: * int int
627:increment_i
stack: * int int
628:convert_i
stack: * int int
629:setlocal 11
stack: * int
631:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
633:convert_d
stack: Number
634:setlocal 13
stack:
636:debugline 316
stack:
639:getlocal2
stack: Bezigon?
640:getlocal 12
642:getlocal 13
644:callproperty add 2
stack: void?
648:pop
stack:
649:debugline 317
stack:
652:jump 779
B5:
stack:
656:label
stack:
657:jump 779
B6:
stack:
661:debugline 292
stack:
664:getlocal 9
stack: Object?
666:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::cmds
stack: *
669:getlocal 10
stack: * int
671:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::[]
stack: *
673:setlocal 14
stack:
675:debugline 293
stack:
678:findpropstrict flash.display::GraphicsPathCommand
stack: global
681:getproperty flash.display::GraphicsPathCommand
stack: flash.display::GraphicsPathCommand$?
684:getproperty MOVE_TO
stack: int
687:getlocal 14
stack: int *
689:ifstrictne 699
stack:
693:pushshort 0
stack: int
695:jump 760
B7:
stack:
699:debugline 305
stack:
702:findpropstrict flash.display::GraphicsPathCommand
stack: global
705:getproperty flash.display::GraphicsPathCommand
708:getproperty LINE_TO
stack: int
711:getlocal 14
stack: int *
713:ifstrictne 723
stack:
717:pushshort 1
stack: int
719:jump 760
B8:
stack:
723:debugline 310
stack:
726:findpropstrict flash.display::GraphicsPathCommand
stack: global
729:getproperty flash.display::GraphicsPathCommand
732:getproperty CURVE_TO
stack: int
735:getlocal 14
stack: int *
737:ifstrictne 747
stack:
741:pushshort 2
stack: int
743:jump 760
B9:
stack:
747:pushfalse
stack: Boolean
748:iffalse 758
stack:
752:pushshort 3
stack: int
754:jump 760
B10:
stack:
758:pushshort 3
B11:
stack: int
760:kill 14
stack: int
762:lookupswitch default:656 maxcase:3 419 480 541 656
B12:
stack:
779:debugline 291
stack:
782:getlocal 10
stack: int
784:increment_i
stack: int
785:convert_i
stack: int
786:setlocal 10
B13:
stack:
788:getlocal 10
stack: int
790:getlocal 9
stack: int Object?
792:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::cmds
stack: int *
795:getproperty {public,PlotText.as$109,PlotText,,http://adobe.com/AS3/2006/builtin,flash.text,PlotText,PlotText,PlotObjekt,Material,flash.display:Sprite,flash.display:DisplayObjectContainer,flash.display:InteractiveObject,flash.display:DisplayObject,flash.events:EventDispatcher,Object}::length
stack: int *
798:iflt 414
VerifyError: Error #1068: PlotText und PlotText können nicht angeglichen werden.
at PlotText/bezigon()
at Arbeitsbereich/bezmsgbox_choose()[/home/wolfgang/Plotservice/Arbeitsbereich.as:2142]
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at Msgbox/okbtn()[/home/wolfgang/Plotservice/Msgbox.as:68]
273 override public function bezigon():Array
274 {
275 var ret:Array = [];
276 var b:Bezigon = new Bezigon();
277 ret.push(b);
278 for(var n:int = 0 ; n < letters.length ; n++)
279 { var l:Letter = letters
280 var fmt:PlotTextFormat = l.getPlotTextFormat();
281 var font:FontOutlines = FontManager.getOutlineFont(fmt.font, fmt.bold, fmt.italic);
282 // sonst noch relevant? (schon in mtx enthalten): condense, slant, yoffs
283 var mtx:Matrix = l.transform.matrix;
284 var sc:Number = Number(fmt.size) / 1024;
285 mtx.a *= sc; mtx.b *= sc; mtx.c *= sc; mtx.d *= sc;
286 mtx.ty += l.ht;
287 trace('text '+l.text+' mtx '+mtx);
288 var cdata:Object = font.getOutlineData(l.text.charCodeAt(0), mtx);
289 //trace('path '+cdata.path);
290 var ni:int, np:int, xv:Number, yv:Number;
291 for(ni = np = 0 ; ni < cdata.cmds.length ; ni++)
292 { switch(cdata.cmds[ni])
293 { case GraphicsPathCommand.MOVE_TO:
294 if(b.length)
295 { b[b.length-1] = b[0];
296 b.closed = true;
297 b = new Bezigon();
298 ret.push(b);
299 }
300 // xv = cdata.path[np++];
301 // yv = cdata.path[np++];
302 // b.add(xv, yv);
303 // break;
304 // fall through
305 case GraphicsPathCommand.LINE_TO:
306 xv = cdata.path[np++];
307 yv = cdata.path[np++];
308 b.add(xv, yv);
309 break;
310 case GraphicsPathCommand.CURVE_TO:
311 xv = cdata.path[np++];
312 yv = cdata.path[np++];
313 b.add(xv, yv, true);
314 xv = cdata.path[np++];
315 yv = cdata.path[np++];
316 b.add(xv, yv);
317 break;
318 }
319 }
320 if(b.length > 0)
321 { b[b.length-1] = b[0];
322 b.closed = true;
323 }
324 trace('bezigon '+b);
325 }
326 return ret;
327 }
that's all error message? there's no trace() output there?
nothing useful... it reported just the line number where the function was called from.
The very last line of that code analysis looks like the verifier had detected an invalid byte code address
what are the first few lines of the error output without any trace output?
well, exactly that...
There was a trace of mine "about to call that func", followed by flash's "verify function()" with all that detail, the #1068 message, and finally the call stack
stack:
is part of your error message? are you using a debugger (or the flash debugger)?
this is running a debug-enabled swf in debug version of standalone player. The long text appears in the flashlog.txt file; the short version just has the "cannot be reconciled" message followed by the call stack
in the flash ide, click control/test movie/and possibly another test. copy and paste the first 20 lines of the error message.
