A customer created a db with a (Varchar)field that holds a
list of number and char example...(123CA65)
She receives about 200 of these numbers that she has to
verify that they exist or not in the database. When I input 2 of
the numbers of the list (one that I know is in the DB and one that
is not) my output returns no record found..However if I just
process the one that is in the database it returns 1 record found.
I have tried using IN instead of Like is my query but still not
success.....Here is my code
<cfform action="Claire.cfm" method="Post"><
<cftextarea name="status" row="38" cols="100"
required="yes"></textarea>
<input="submit"></cform>
<cfquery name="Tri" datasource="Corport"> Select Code
from Dept where code like '%#Status#%'</cfquery>
<cfset
agentlist="#Replace(Status,"#char(13)#","<br>","ALL")#"
<cfif #Tri.recordcount# GT
0><cfoutput>#agentList#</cfoutput>
<cfelse>No records found</cfif>
