3 Replies Latest reply: Dec 21, 2010 7:25 AM by jenlaurentate RSS
    I thought it was aligned...
    jenlaurentate Community Member
      I just published this site for a friend of mine:
      www.paintingbydarlene.com and it looks fine in all browers on my laptop as well as my iPhone, but when my friend looks at it on his computer, the aligning is
      off. When I look at it in my computer at work, the aligning is off as well. I assume it's because of the bigger screens, but how do I fix this issue so that everything shows up in the grey box in all browers, regardless of the screen size? I added a "center" tag at the top of the coding and "/center" at the bottom, but obviously that didn't work. Any suggestions?
        • 1. Re: I thought it was aligned...
          Captiv8r CommunityMVP
          Hi there
          What Adobe product are you using? You posted in a forum dedicated for supporting Adobe RoboHelp and I'm doubtful that you are using RoboHelp.
          Assuming you posted a legitimate question, you need to re-post this in the forum where the product you are using is discussed.
          Cheers... Rick
          • 2. Re: I thought it was aligned...
            Willam van Weelden CommunityMVP
            Doesn't look like RoboHelp to me
            Anyway, replace the central <center> by <div id="centerplaceholder"> and add the following css:
            div#centerplaceholder {
            width: 921px;
            margin: 0 auto;
            position: relative;
            (Don't forget the </center> tag.) You may also want to consider to turn the grey image into a css background image to improve page performance.
            Greet,
            Willam
            • 3. Re: I thought it was aligned...
              I had a really hard time finding a forum that was in line with what I needed. I was under the impression that I was in a Dreamweaver Layout Issues area, but now that I'm looking at the hierarchy, I can see that I am NOT in a Dreamweaver Layout Issue forum..Oopsies!
              Thanks for the help, I will try that code and see what happens
