Processing a list with varchar datatype code attached
Jun 19, 2006 Jun 19, 2006
A customer created a db with a (Varchar)field that holds a list of number and char example...(123CA65)
She receives about 200 of these numbers that she has to verify that they exist or not in the database. When I input 2 of the numbers of the list (one that I know is in the DB and one that is not) my output returns no record found..However if I just process the one that is in the database it returns 1 record found. I have tried using IN instead of Like is my query but still not success.....Here is my code
<cfform action="Claire.cfm" method="Post"><
<cftextarea name="status" row="38" cols="100" required="yes"></textarea>
<input="submit"></cform>
<cfquery name="Tri" datasource="Corport"> Select Code from Dept where code like '%#Status#%'</cfquery>
<cfset agentlist="#Replace(Status,"#char(13)#","<br>","ALL")#"
<cfif #Tri.recordcount# GT 0><cfoutput>#agentList#</cfoutput>
<cfelse>No records found</cfif>
Advanced techniques
317
Guest
might be silly Question but did u tried using Upper(Trim(Code)) IN Upper(TRIM('#Status#'))? or one of the combination ?
I'm actually trying to figure out when I put 1 set of numbers in the text area and submit it that it returns a record found but when
I put in more numbers it tells me no records found when I know 1 set of the numbers exist. the input looks like this
12145897,
18PL698-78934CA,
12568pl69
Participant ,
1. You cannot use LIKE to search on multiple patterns.
2. You have to replace <cr><lf> with "," and use IN
Documentation
