Hi ,
I am submitting the form data in xml format to a servlet using the submit button . I also need to pass one parameter with the URL . But the value of that parameter changes at runtime depending on the value of a particular field on the form . Please help me out with it .
Thanks .
Solved! Go to Solution.
Total Likes
Here is a sample that shows what I think you want. The code is on th epreSubmit event of the button. I put messages out showing what the button thinks the submit URL is......before and after we change it. You can remove those messages when you get it working the way you want.
Hope that helps
Paul
Total Likes
Then you woudl have to programatically set the submit URL. To get access to the submit URL use:
SubmitButtonName.event_click.submit.target = "Your submit URL"
This will accept a string so you can construct the URL whatever way you want. Of course this would need to be done before the user pressed the submit button .....I woudl use the preSubmit event.
Paul
Total Likes
Please mind my ignorance but i am not able to implement it . I am a little confused with the type of button and events . Also i needed the form to be submitted in xml data format. Can you help me with the sample of it . Thanks .
Total Likes
Hope that helps
Paul
Total Likes
Thanks so much pguerett.
It's really helpful for me.
BTW, i would like to ask additional question related on it.
Suppose the client side have a html page with a url, when the user click on the link, how the adobe livecycle directly receive the link that clicked from the user? is it possible to do that? Please advise.
Thanks a lot.
Total Likes
