Hello,
is there any modbus module to communicate with Modbus protocol in TCP-mode, like as http://www.automatedsolutions.com/products/modbustcp.asp for Flash?
Cheers
Giacomo
Any others ModBus modules are ok. Can yo suggest me any solution, please?
I am currently developing a Modbus TCP library for use in Flex 4 projects. Is that the sort of thing you are looking for? If so would you like for me to contact you when it is available?
Dave
Yes, please contact me when it will be ready.
Hi, I´m sitting here armwrestling with my ModbusTCP/RTU converter and trying to cennect it from a flash app!
And i´ll just found this post, now i´m whodering if any of your got it to work?
Regard BjarkeSS
I just recently finished a library that allows you to communicate from a Flash/Flex application to a MdobusTCP device. You can find more information here: http://solydest.com/blog/projects/asmodbus/. A direct link to the ASDocs is here: http://www.solydest.com/asmodbus/docs/.
This library does not depend on the Adobe AIR runtime but should work just fine with it.
Hope this is helpful.
Dave
Looking great! I´ll will take a god look at it in next week, but i think you just saved me for, weeks of work here...
I´ll let you now my experience......
Regard BjarkeSS
Hi Solydest,
I need your help on asmodbus,
I seached all the network and can not find anything except for yours help.
Could you help to contact with me when you see this message?
thanks a lot! my mail:novolei@gmail.com
thanks a lot! looking for your help and want to ask you how to use the lib of asmodbus.
Hello,
I try to find information to make a communication between a PLC and a flash animation by the Modbus protocol.
On this post I can not reach the address http://solydest.com/blog/projects/asmodbus/
Does anyone have information to help me achieve this communication.
I download it here https://github.com/solydest the Modbus library in Actionscript 3 but I can not use it.
Thank you for your help.
I´ll didn’t get this to work .... so I ended up making the communication myself.
What you need to do is to make a Ethernet socket/TCP connection to the PLC.
and then make the string as the modbus/tcp protocol describes it, an then you are up and running!
BjarkeSS
