1. Re: Text help
[scott] Dec 20, 2010 9:56 PM (in response to mhossey)Select the boxes and choose Object > Compound Path > Release
2. Re: Text help
mhossey Dec 21, 2010 8:41 AM (in response to [scott])Thats what I thought but the "release" option isnt available
3. Re: Text help
[scott] Dec 21, 2010 11:29 AM (in response to mhossey)Ungroup maybe?
But even in a group, if using the Direct Selection Tool, the boxes should be individually fillable.
4. Re: Text help
Larry G. Schneider Dec 21, 2010 11:36 AM (in response to mhossey)Can you post a picture of the objects selected with tthe Appearance panel open to show what's going on? To me it looks like a gradient was used across the boxes, maybe at a layer level.
5. Re: Text help
mhossey Dec 21, 2010 11:36 AM (in response to [scott])I tried ungrouping as well and it didnt work....I decided to just create the boxes behind it instead of using the font...looks the same.
Thanks for the help anyways guys I apprecitate it
6. Re: Text help
mhossey Dec 21, 2010 11:44 AM (in response to Larry G. Schneider)How do i take a screenshot in Illy?
7. Re: Text help
Larry G. Schneider Dec 21, 2010 11:50 AM (in response to mhossey)Which OS? On a Mac, it's Cmd-Shift-4 and then drag the area you want.
8. Re: Text help
mhossey Dec 23, 2010 7:32 AM (in response to Larry G. Schneider)PC, I tried taking a screen shot with "print screen" but it didnt work
9. Re: Text help
Jacob Bugge Dec 23, 2010 7:58 AM (in response to mhossey)mhossey,
What happens if you Ctrl+PrintScreen and then Ctrl+V in another document (and then crop)?
10. Re: Text help
mhossey Dec 23, 2010 8:01 AM (in response to Jacob Bugge)Nothing, It doesn't work like when you take screenshot of a webpage.....does it work when you do it?
11. Re: Text help
It does; I am still with 10.
When you create the boxes without the font, what about the slanting cutoffs?
I wondered whether you created a Compound Shape rather than a Compound Path.
A different way of creating the slanting cutooffs, maybe a bit more laborious but without any issues, would be to release the compound path of the A, remove the fills from the paths of the letters and the connecting part, and apply Object>Path>Divide Objects below. That should cut the affected boxes, and you may remove all the unwanted boxes/parts.
