Hi Steph,
Thanks for posting the code. Three posibilities:
1. Header place holder
So when you removed the place holder
<!--kadov_tag{{<placeholder id="header">}}-->
and everything was fine?
You could try removing it again, but this time, instead of
putting in a line break, change the style of the Heading 1 to have
the Spacing before set to 12pt (or whatever space you need) and see
if the _ or - is still showing?
2. Background image
I also have one question about the code you posted. The image
that you use for the background ps_help_bg.jpg" -
background-position: Right Top;
Can you take a close look at that image? is there a spurious
- or _ in the background image somewhere? If so, you may need to
edit and removed the 'dirty mark' in this image.
3. Template
You can put a header and footer in a template (so that it is
applied to every topic). I noticed that you are using a template
Project Stop.htt:
<meta name="template" content="Project Stop.htt">
It the points 1 and 2 do not resolve the problem, please can
you post the true code from the Project Stop.htt file? thanks.
Hope that helps.
However, if you still have problems, I' happy to take a look
at the source files if you want to email them. I'd just need the
topic (.htm), the template (.htt), stylesheet (.css) and the
background image (ps_help_bg.jpg)
Kind Regards
Craig
