I have two problems and any help would be appreciated!
1) Using Flash Builder Burrito Preview Version when I try to debug it won't publish the apk to my Droid 2, it just hangs at 6% and says "Launching".
I have the latest Google USB Drivers, and I can install the apk to the device manually using "adb install xyz.apk". It has AIR 2.5 installed. I can also see the device when I run "adb devices".
2) When I try to run my app on the Droid 2 it fails and simply doesn't launch. Below is my logcat dump.
Note, I have run this same app on an EVO 4 just fine, and Flash Builder Burrito copied it over to the EVO just fine.
Anyone know what gives with Droid 2?
12-11 17:44:47.598 1235 1374 I ActivityManager: Starting activity: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=air.Mobile1.debug/.AppEntry }
12-11 17:44:47.629 1857 1857 W WidgetAidService: BroadcastReceiver onReceive called
12-11 17:44:47.637 1857 1857 D WidgetAidService: ACTION_HOME_SCREEN_CHANGED - -1
12-11 17:44:47.637 1235 1436 I ActivityManager: Start proc air.Mobile1.debug for activity air.Mobile1.debug/.AppEntry: pid=5513 uid=10103 gids={}
12-11 17:44:47.676 1857 1857 D WidgetAidService: HomeScreen has lost focus, store the previous state and move to pause
12-11 17:44:47.707 1857 1857 D WidgetAidService: Ignoring the HOME_SCREEN_CHANGED notification as the player is either in paused/playing state
12-11 17:44:47.840 5513 5513 I Process : Sending signal. PID: 5513 SIG: 9
12-11 17:44:47.856 1235 1431 I ActivityManager: Process air.Mobile1.debug (pid 5513) has died.
12-11 17:44:47.863 1235 1429 I WindowManager: WIN DEATH: Window{45b745e8 air.Mobile1.debug/air.Mobile1.debug.AppEntry paused=false}
12-11 17:44:47.879 1235 1431 I UsageStats: Unexpected resume of com.motorola.blur.home while already resumed in air.Mobile1.debug
12-11 17:44:47.957 1857 1857 W WidgetAidService: BroadcastReceiver onReceive called
12-11 17:44:47.957 1857 1857 D WidgetAidService: ACTION_HOME_SCREEN_CHANGED - 3
12-11 17:44:47.973 1235 1349 W InputManagerService: Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@45a62e10 (uid=10005 pid=1347)
12-11 17:44:47.973 1235 1427 W InputManagerService: Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@45b6a9a8
Okay, I updated my device to AIR 2.5.1 and presto it solved both of my problems. If you have a similar problem, download AIR 2.5.1 from Android Market.
Just a quick tip that is semi-related...
A quick way to get apk files onto your device is to use Dropbox. I have Flash Builder set to create the apk file directly in a subfolder in Dropbox. Then I open it on the device and it starts installing!
NOTE: You have to have your device setup to install non-market apps to do this... Menu > Settings > Applications > Check "Unknown Sources"
