2 Replies Latest reply on Jan 4, 2011 3:16 PM by _durin_
    Repeated crash at launching
    Alivalhur
      No problem during 2 weeks. then I changed an option in preferences: seems that was that Adobe Audition manages the interface options...
      After that a crash and now craches at every launch.
      - I restart the computer but no result
      - I erase the preferences and reinstall but no result.
      Hereunder the crash report:
      Process:         Adobe Audition [5064]
      Path:            /Applications/Adobe Audition.app/Contents/MacOS/Adobe Audition
      Identifier:      com.adobe.Audition.4.0
      Version:         4.0x10 (4.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [161]
      Date/Time:       2010-12-26 17:58:22.197 +0100
      OS Version:      Mac OS X 10.6.5 (10H574)
      Report Version:  6
      Interval Since Last Report:          265046 sec
      Crashes Since Last Report:           208
      Per-App Interval Since Last Report:  733519 sec
      Per-App Crashes Since Last Report:   6
      Anonymous UUID:                      3B596F19-472C-4045-9EB3-85D65580C911
      Exception Type:  EXC_CRASH (SIGABRT)
      Exception Codes: 0x0000000000000000, 0x0000000000000000
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      abort() called
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   libSystem.B.dylib                 0x97da7176 __kill + 10
      1   libSystem.B.dylib                 0x97da7168 kill$UNIX2003 + 32
      2   libSystem.B.dylib                 0x97e3989d raise + 26
      3   libSystem.B.dylib                 0x97e4f9bc abort + 93
      4   libstdc++.6.dylib                 0x9871dfda __gnu_cxx::__verbose_terminate_handler() + 433
      5   libstdc++.6.dylib                 0x9871c17a __cxxabiv1::__terminate(void (*)()) + 10
      6   libstdc++.6.dylib                 0x9871c1ba __cxxabiv1::__unexpected(void (*)()) + 0
      7   libstdc++.6.dylib                 0x9871c2b8 __gxx_exception_cleanup(_Unwind_Reason_Code, _Unwind_Exception*) + 0
      8   AuUI                              0x03bac550 BIB_T_NMT::BIBThrowError(BIBError*) + 272
      9   AuUI                              0x03c10fc3 dvaui::drawbot::AGMTextDoc::GetLineBounds(int) const + 1107
      10  AuUI                              0x03bef17c dvaui::drawbot::AGMFontInterface::MeasureMultiLineStringHeight(unsigned short const*, float, int) const + 460
      11  com.adobe.dvaui.framework         0x004eca22 dvaui::controls::UI_StaticText::GetRecommendedSize_Helper(dvaui::drawbot::Drawbot*, bool) const + 818
      12  com.adobe.dvaui.framework         0x004ecb90 dvaui::controls::UI_StaticText::UI_GetRecommendedSize(dvaui::drawbot::Drawbot*) const + 32
      13  com.adobe.dvaui.framework         0x0061afdc dvaui::ui::(anonymous namespace)::LayoutNode::operator()(boost::intrusive_ptr<dvaui::ui::UI_Node>) + 860
      14  com.adobe.dvaui.framework         0x0061b566 dvaui::ui::(anonymous namespace)::LayoutNode std::for_each<__gnu_cxx::__normal_iterator<boost::intrusive_ptr<dvaui::ui::UI_Node>*, std::vector<boost::intrusive_ptr<dvaui::ui::UI_Node>, std::allocator<boost::intrusive_ptr<dvaui::ui::UI_Node> > > >, dvaui::ui::(anonymous namespace)::LayoutNode>(__gnu_cxx::__normal_iterator<boost::intrusive_ptr<dvaui::ui::UI_N ode>*, std::vector<boost::intrusive_ptr<dvaui::ui::UI_Node>, std::allocator<boost::intrusive_ptr<dvaui::ui::UI_Node> > > >, __gnu_cxx::__normal_iterator<boost::intrusive_ptr<dvaui::ui::UI_Node>*, std::vector<boost::intrusive_ptr<dvaui::ui::UI_Node>, std::allocator<boost::intrusive_ptr<dvaui::ui::UI_Node> > > >, dvaui::ui::(anonymous namespace)::LayoutNode) + 70
      15  com.adobe.dvaui.framework         0x00618b19 dvaui::ui::AutoLayoutSubView(boost::intrusive_ptr<dvaui::ui::UI_SubView>, dvaui::drawbot::Drawbot*) + 441
      16  com.adobe.dvaui.framework         0x005e3789 dvaui::ui::UI_SubViewAdapter::AutoLayout(dvaui::drawbot::Drawbot*, boost::intrusive_ptr<dvaui::ui::UI_Node>, boost::intrusive_ptr<dvaui::ui::UI_Node>) const + 41
      17  com.adobe.dvaui.framework         0x006220f8 dvaui::ui::UI_NodeArchive::CreateNode(boost::intrusive_ptr<dvaui::ui::UI_Node>, dvacore::proplist::PropList const&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 2328
      18  com.adobe.dvaui.framework         0x006229e9 dvaui::ui::UI_NodeArchive::BuildFromPropList(dvacore::proplist::PropList const&, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 217
      19  com.adobe.dvaui.framework         0x00622c0a dvaui::ui::UI_NodeBuilder::Build(dvaui::drawbot::SupplierInterface const*, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) const + 122
      20  com.adobe.dvaui.framework         0x005a132a dvaui::sharedui::DVAAboutDlog::ConstructCommon(dvaui::utility::ResourceManager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 1610
      21  com.adobe.dvaui.framework         0x005a1f74 dvaui::sharedui::DVAAboutDlog::DVAAboutDlog(dvaui::utility::ResourceManager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 436
      22  AuUI                              0x03467e53 aui::SplashScreen::SplashScreen(dvaworkspace::workspace::Workspace*, dvaui::utility::ResourceManager*) + 243
      23  AuUI                              0x03443b31 aui::Application::GetNewSplashScreen() + 65
      24  com.adobe.exo.framework           0x0191fe9f exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 623
      25  AuUI                              0x03446276 aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 38
      26  AuUI                              0x0346939f AudMacMain(int, char**) + 415
      27  com.adobe.Audition.4.0            0x00002ecd main + 93
      28  com.adobe.Audition.4.0            0x00002c66 start + 54
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib                 0x97d6c982 kevent + 10
      1   libSystem.B.dylib                 0x97d6d09c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib                 0x97d6c559 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib                 0x97d6c2fe _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib                 0x97d6bd81 _pthread_wqthread + 390
      5   libSystem.B.dylib                 0x97d6bbc6 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib                 0x97d6ba12 __workq_kernreturn + 10
      1   libSystem.B.dylib                 0x97d6bfa8 _pthread_wqthread + 941
      2   libSystem.B.dylib                 0x97d6bbc6 start_wqthread + 30
      Thread 3:
      0   libSystem.B.dylib                 0x97d740a6 __semwait_signal + 10
      1   libSystem.B.dylib                 0x97d73d62 _pthread_cond_wait + 1191
      2   libSystem.B.dylib                 0x97d759f8 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore    0x9663f51e TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore    0x9662aea5 TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore    0x96626873 MPWaitOnQueue + 250
      6   AdobeACE                          0x05272e79 0x5232000 + 265849
      7   AdobeACE                          0x05272871 0x5232000 + 264305
      8   ...ple.CoreServices.CarbonCore    0x9660a85a PrivateMPEntryPoint + 68
      9   libSystem.B.dylib                 0x97d7385d _pthread_start + 345
      10  libSystem.B.dylib                 0x97d736e2 thread_start + 34
      Thread 4:
      Thread 5:
      Thread 6:
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000000  ebx: 0x97e4f96b  ecx: 0xbfffe8cc  edx: 0x97da7176
        edi: 0xa09beb30  esi: 0x061c1f6c  ebp: 0xbfffe8e8  esp: 0xbfffe8cc
         ss: 0x0000001f  efl: 0x00000282  eip: 0x97da7176   cs: 0x00000007
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x03d92d4c
      Binary Images:
          0x1000 -     0x2ff7 +com.adobe.Audition.4.0 4.0x10 (4.0) <1987E7D4-6A62-4AD7-0CC0-57AAFBF937C0> /Applications/Adobe Audition.app/Contents/MacOS/Adobe Audition
         0x12000 -    0x16ffc +com.adobe.AdobeCrashReporter 2.5 (3.0.20090403) /Applications/Adobe Audition.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
         0x1c000 -    0x38fd7 +com.adobe.LogTransport 1.0 (1.0) /Applications/Adobe Audition.app/Contents/Frameworks/LogTransport.framework/Versions/A/LogTransport
         0x43000 -    0x49fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.227407) <43FFF5DD-EB22-BA79-ADA7-CE764691A3FA> /Applications/Adobe Audition.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x5b000 -    0x62ff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.227407) <A4543C73-7576-87A8-0F82-EDA4399AA816> /Applications/Adobe Audition.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x72000 -    0x7cffd +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.227407) <008D30F2-1FA5-2CB6-47D4-B681C4271647> /Applications/Adobe Audition.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
         0x8f000 -    0x90ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.227407) <B5F6001A-DDB9-28D0-200C-784CEA3867A1> /Applications/Adobe Audition.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
         0x98000 -   0x225fef +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.227407) <1A2036D5-23CA-97DD-1CC9-197CA598B90A> /Applications/Adobe Audition.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x3a3000 -   0x705fff +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.227407) <4CCEF8A1-AEF9-A025-E127-0A8B053E76BE> /Applications/Adobe Audition.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
        0xaa8000 -   0xe25ff3 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.227407) <C2CA6AAF-79FB-41DC-ECF2-9B5D05789E11> /Applications/Adobe Audition.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
      0x1394000 -  0x1441fff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.227407) <35F0D2FF-1AA9-B4EB-7C86-86B3AA51A24C> /Applications/Adobe Audition.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
      0x1514000 -  0x1536ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.227407) <B9489EB1-6251-C8FA-5ABE-B1D2835371F0> /Applications/Adobe Audition.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
      0x1557000 -  0x15b6fff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.227407) <706687D1-99B2-D6A6-6D77-6E61F9204AB6> /Applications/Adobe Audition.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
      0x163f000 -  0x1697ff7 +AdobeXMP ??? (???) <FC80E7A2-D150-D5A8-9AEE-879B05153A34> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x16a6000 -  0x174cff3 +AdobeXMPFiles ??? (???) <CB814673-A68C-01E2-84A9-500FA0D0E902> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
      0x1788000 -  0x181afff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.227407) <8242B12A-1DA3-0097-9D67-3914F3525A8E> /Applications/Adobe Audition.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
      0x18b3000 -  0x18fcfff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.227407) <89DD2C45-7B77-63BE-08AB-C65F62D8BB16> /Applications/Adobe Audition.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
      0x191d000 -  0x19c7fff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.227407) <3AFC9275-FC8A-12BA-9DEE-12E06A84346F> /Applications/Adobe Audition.app/Contents/Frameworks/exo.framework/Versions/A/exo
      0x1ac1000 -  0x1adfff3 +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.227407) <CEFB69C2-2B6F-4803-1E76-2A7C27DB7365> /Applications/Adobe Audition.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
      0x1b09000 -  0x1b14fff +com.adobe.aucore.framework 1.0 (1.0) <5138C72A-D709-15C9-C7CF-2DFB0BB63557> /Applications/Adobe Audition.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
      0x1b21000 -  0x1cf8ff2 +com.adobe.audsp.framework 1.0 (1.0) <1D00C1BB-2239-0682-A7D4-7C0EB91D746F> /Applications/Adobe Audition.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
      0x1d89000 -  0x1ebefef +com.adobe.auaudiocomponents.framework 1.0 (1.0) <CAD732EE-D001-D483-B0B0-DDAB3CB7632E> /Applications/Adobe Audition.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/AuAudioComponents
      0x1fb6000 -  0x232aff7 +com.adobe.aubackend.framework 1.0 (1.0) <839C916A-0B01-35CB-481D-1A11B58A2708> /Applications/Adobe Audition.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
      0x263c000 -  0x2643fff +com.adobe.dvaundo.framework dvaundo version 5.0.0 (5.0.0.227407) <C879499B-14BE-2A58-E3A9-16A22BCB8599> /Applications/Adobe Audition.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
      0x264f000 -  0x2980fef +AuApplication ??? (???) <B85693EC-7B9B-8FF2-8224-A867FDADE88A> /Applications/Adobe Audition.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuApplication
      0x2c4f000 -  0x2d32feb +com.adobe.auuitoolkit.framework 1.0 (1.0) <11FC9733-4040-4DF9-7BAD-2AAF1C698681> /Applications/Adobe Audition.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUIToolkit
      0x2e7a000 -  0x2f12ffb +AdobeExtendScript 4.0.0 (compatibility 4.0.0) <46913918-DC81-801B-64CA-20859142B7CD> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
      0x2f71000 -  0x2ff7ff7 +com.adobe.AdobeScCore ScCore 4.0.5 (4.0.5.3233) <C43541AF-83A7-E11D-50FB-1EC7D6120AE9> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
      0x3038000 -  0x3149ffb +com.adobe.auscripting.framework 1.0 (1.0) <9F05F5C5-D1DA-4C5F-E8CA-EF6062622853> /Applications/Adobe Audition.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScripting
      0x32d2000 -  0x3341fff +com.adobe.auaudiocomponentsui.framework 1.0 (1.0) <FB33D5F0-5DD9-CD3D-4FDB-97354B9B1C97> /Applications/Adobe Audition.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/AuAudioComponen tsUI
      0x33df000 -  0x3d5afef +AuUI ??? (???) <2A0283CA-D85F-B907-8C85-F1A53E4C902D> /Applications/Adobe Audition.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
      0x4671000 -  0x46b1ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x46ca000 -  0x46d4ff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.227407) <C782506A-EB8B-535F-9FAA-DD68C619DC75> /Applications/Adobe Audition.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
      0x46e8000 -  0x4765fe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.227407) <F3CC925C-2244-6042-FA7D-27B548CD668A> /Applications/Adobe Audition.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
      0x47ca000 -  0x489efef +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.227407) <DBD4A2D4-2153-724E-DB7A-E7CEF3F4298E> /Applications/Adobe Audition.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
      0x4998000 -  0x49c1fe3  com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
      0x49d2000 -  0x4abaccb +iZBase ??? (???) <773F066F-8FBE-4947-BA51-D3A1BC62D2E1> /Applications/Adobe Audition.app/Contents/Frameworks/iZBase.framework/Versions/A/iZBase
      0x4b37000 -  0x4b9be48 +iZDSPBase ??? (???) <C1575F2E-CE46-43AD-8F48-D15B7097F082> /Applications/Adobe Audition.app/Contents/Frameworks/iZDSPBase.framework/Versions/A/iZDSPBase
      0x4bb4000 -  0x4c4a3a6 +iZotope_Radius ??? (???) <B6AF5A0A-6CFD-4298-8450-9FD830471654> /Applications/Adobe Audition.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZotope_Radius
      0x4c87000 -  0x4cddffb +com.adobe.headlights.LogSessionFramework ??? (2.1.0.1075) <ABE97AAF-C5A9-C729-63D9-73FFB791BDE2> /Applications/Adobe Audition.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x4d26000 -  0x4fb4fec +libxerces-c-3.0.dylib ??? (???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition.app/Contents/Frameworks/libxerces-c-3.0.dylib
      0x5137000 -  0x51ecfe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
      0x5232000 -  0x5355ff7 +AdobeACE ??? (???) <6B4856DC-3D41-CEF7-CB70-D02EEA97B8D2> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x5378000 -  0x5a52ff3 +AdobeAGM ??? (???) <FE943B4D-ED58-F753-8AE8-54E753A773BD> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x5b17000 -  0x5b34ff7 +AdobeBIB ??? (???) <6CC35ACF-5CCD-1509-B4BB-3B48AD140526> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x5b3b000 -  0x5b61ffb +AdobeBIBUtils ??? (???) <B9888BEE-A939-50E3-1CD3-3313AC14A073> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x5b68000 -  0x5e97ff3 +com.adobe.CoolType AdobeCoolType 5.10.7.10201 (5.10.7.10201) <6810A678-B1DF-F96D-2560-25AE3FDA923A> /Applications/Adobe Audition.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x5ee9000 -  0x5f56ffb +com.adobe.amtlib amtlib 3.5.0.34 (3.5.0.34) <8C1EBC9E-DDFF-660B-03FB-196CE8A4CED8> /Applications/Adobe Audition.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x5f6d000 -  0x5f71ff3 +com.adobe.dvaflashview.framework dvaflashview version 5.0.0 (5.0.0.227407) <93CDD4AA-187D-5C06-1BA3-EA414516018B> /Applications/Adobe Audition.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
      0x5f7b000 -  0x5f7eff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Audition.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x6740000 -  0x674cff7 +com.rogueamoeba.audio_hijack_server.hermes 3.0.0 (3.0.0) <4EC060B6-D7D5-DA11-A2D3-F469367629BF> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
      0x67db000 -  0x67edff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x87be000 -  0x87bfff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x87c9000 -  0x87d7fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x1c822000 - 0x1c827ff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <4591F641-2C45-64A2-6C1C-C1722076B7F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <28F0312C-0678-159E-34E2-9A4E3DEADB20> /usr/lib/dyld
      0x91005000 - 0x91085feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x91086000 - 0x91086ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x91624000 - 0x91753fe3  com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x91754000 - 0x917cefff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x918fc000 - 0x918ffff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x91900000 - 0x91941ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x91942000 - 0x91962fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
      0x91996000 - 0x919baff7  libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x919bb000 - 0x919bbff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x91be4000 - 0x91c28ff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x91c5c000 - 0x91c82ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x91cb8000 - 0x91d71fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
      0x91d72000 - 0x91e04fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x91e05000 - 0x91f11ff7  libGLProgrammability.dylib ??? (???) <8B308FAE-843F-EE76-0254-3374CBFFA7B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x91f12000 - 0x91f81ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x91f82000 - 0x91f86ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x91f87000 - 0x92140feb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C145139E-24C4-5A3D-B17C-809D528354B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x92141000 - 0x9217aff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <D6F24434-8217-DF72-2126-1953080680D7> /usr/lib/libcups.2.dylib
      0x9217b000 - 0x92186ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x92187000 - 0x921a2ff7  libPng.dylib ??? (???) <E14178E0-B92D-94EA-DACB-04F346D7534C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x9265d000 - 0x92a73ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x92a74000 - 0x92a77ff7  libCoreVMClient.dylib ??? (???) <1F738E81-BB71-32C5-F1E9-C1302F71021C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x92a78000 - 0x92ab0fe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
      0x92ab1000 - 0x92af5fe7  com.apple.Metadata 10.6.3 (507.12) <8632684D-ED4C-4CE1-4C53-015DFF10D873> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x92bfd000 - 0x92c03fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x92d00000 - 0x92d38ff7  com.apple.LDAPFramework 2.0 (120.1) <001A70A8-3984-8E19-77A8-758893CC128C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x92d75000 - 0x92db0feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x92db1000 - 0x92df3ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x92df4000 - 0x92e08fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
      0x92e09000 - 0x92e0bff7  libRadiance.dylib ??? (???) <10048B4A-2AE8-A4E2-21B8-C6E7A8C5B76F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x92e19000 - 0x92f94fe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x92f95000 - 0x9305ffef  com.apple.CoreServices.OSServices 357 (357) <8E13E1FB-6EBD-780B-6B08-B37118311071> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x93060000 - 0x930a6ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
      0x930a7000 - 0x9330afef  com.apple.security 6.1.1 (37594) <1949216A-7583-B73A-6112-4D55CA5852E3> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x9330b000 - 0x9332cfe7  com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x9333e000 - 0x9335afe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x9335b000 - 0x9336dff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x940af000 - 0x941b0fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
      0x941ca000 - 0x9422effb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x942a4000 - 0x942f5ff7  com.apple.HIServices 1.8.1 (???) <51BDD848-32A5-2425-BE07-BD037A89630A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x9430a000 - 0x9434dff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x94359000 - 0x943a9ff7  com.apple.framework.familycontrols 2.0.1 (2010) <9F2045F3-DAC5-D976-F47E-27C58F80585D> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x943d4000 - 0x94405ff7  libGLImage.dylib ??? (???) <78F59EAB-BBD4-7366-CA84-970547501978> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x94406000 - 0x94409ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x94428000 - 0x944d8ff3  com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x94750000 - 0x9475dff7  com.apple.NetFS 3.2.1 (3.2.1) <A6443845-5815-2429-7649-C51A4B5E7DF9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x9476c000 - 0x9476cff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x947be000 - 0x947ceff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x9495c000 - 0x94970ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x94b5f000 - 0x94b6aff7  libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x94b6b000 - 0x94b79ff7  com.apple.opengl 1.6.11 (1.6.11) <286D1BC4-4CD8-3CD4-F723-5C196FE15FE0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x94ba5000 - 0x94bacff7  com.apple.agl 3.0.12 (AGL-3.0.12) <536EC13F-815E-0A23-CFE2-CC73BBED2DF8> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x94bb0000 - 0x94bb4ff7  libGIF.dylib ??? (???) <DA5758A4-71B0-DD6E-7402-B7FB15387569> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x94de1000 - 0x94de1ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x94de2000 - 0x94f64fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
      0x94fe7000 - 0x957d6557  com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x95c24000 - 0x95c24ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x95c25000 - 0x95c28fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x95c29000 - 0x95c3aff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x95c3b000 - 0x9651bff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x9655d000 - 0x9655dff7  com.apple.Carbon 150 (152) <BD34A993-AF6F-10EE-ACDA-6D11E21A8F37> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x9655e000 - 0x965e0ffb  SecurityFoundation ??? (???) <006B3166-E7E2-F763-04FC-3DD458C14F5F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x965e4000 - 0x96904ff3  com.apple.CoreServices.CarbonCore 861.23 (861.23) <B08756E4-32C5-CC33-0268-7C00A5ED7537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x96905000 - 0x96906ff7  com.apple.TrustEvaluationAgent 1.1 (1) <FEB55E8C-38A4-CFE9-A737-945F39761B4C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x96907000 - 0x96944ff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x96976000 - 0x96a7afe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
      0x96c06000 - 0x96c3dfe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
      0x96c65000 - 0x96d40feb  com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x96f3f000 - 0x97374ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x973ed000 - 0x97430ff7  libGLU.dylib ??? (???) <F8580594-0B38-F3ED-A715-CB3776B747A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x9743d000 - 0x97452fff  com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x97453000 - 0x9745dffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x974cd000 - 0x97500ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x9770b000 - 0x97758feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <8B819445-BDC3-74BD-4A7B-D650E511F0BF> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x97759000 - 0x977f1fe7  edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x978f5000 - 0x97917fef  com.apple.DirectoryService.Framework 3.6 (621.9) <F2EEE9D7-D4FB-14F3-E647-ABD32754F557> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x97918000 - 0x97c83ff7  com.apple.QuartzCore 1.6.3 (227.34) <CC1C1631-D8D1-D416-171E-A1683274E479> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x97c84000 - 0x97d31fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
      0x97d45000 - 0x97eecff7  libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
      0x97eed000 - 0x98211fef  com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x98212000 - 0x98212ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x98223000 - 0x982cbffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x9830f000 - 0x98327ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x98328000 - 0x9832cff7  libGFXShared.dylib ??? (???) <C3A805C4-C0E5-B300-430A-7E811395CB8E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x98654000 - 0x986b1ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x986b2000 - 0x986d1ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x986d2000 - 0x9873cfe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x9873d000 - 0x987dafe3  com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x987db000 - 0x98876ff7  com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x98954000 - 0x98960ff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
      0x98961000 - 0x98a0fff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x98a10000 - 0x98a19ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x98c19000 - 0x98d47fe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x98d48000 - 0x98da9fe7  com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x98daa000 - 0x98dabff7  com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x98dac000 - 0x98dd4ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x98dd5000 - 0x98e8bff7  libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x98e8c000 - 0x98e93ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x98e94000 - 0x98e9efe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x98eb2000 - 0x98ec0fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
      0x98ec3000 - 0x99136fe7  com.apple.Foundation 6.6.4 (751.42) <ACC0BAEB-C590-7052-3AB2-86C207C3D6D4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x99150000 - 0x9922dff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x9922e000 - 0x9922eff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x992e0000 - 0x99329fe7  libTIFF.dylib ??? (???) <AC1FC806-F7F4-174B-375F-FE5D6008666C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x9932b000 - 0x99711ffb  com.apple.RawCamera.bundle 3.4.1 (546) <557C094F-BF8D-B298-E502-C4EE78914C55> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x99925000 - 0x9992aff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x9992b000 - 0x9992dff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x99977000 - 0x99a21fe7  com.apple.CFNetwork 454.11.5 (454.11.5) <D8963574-285A-3BD6-6B25-07D39C6F67A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
      Model: iMac11,3, BootROM IM112.0057.B00, 4 processors, Intel Core i7, 2.93 GHz, 8 GB, SMC 1.59f2
      Graphics: ATI Radeon HD 5750, ATI Radeon HD 5750, PCIe, 1024 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 2.1.14.5
      Bluetooth: Version 2.3.8f7, 2 service, 19 devices, 1 incoming serial ports
      Network Service: Ethernet intégré, Ethernet, en0
      Serial ATA Device: Hitachi HDS722020ALA330, 1,82 TB
      Serial ATA Device: HL-DT-STDVDRW  GA32N
      USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfd100000
      USB Device: Hub, 0x0451  (Texas Instruments), 0x1446, 0xfd140000
      USB Device: LaCie Storage, 0x059f  (LaCie), 0x1029, 0xfd144000
      USB Device: EPSON Scanner, 0x04b8  (Seiko Epson Corp.), 0x0122, 0xfd142000
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0xfd120000
      USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd110000
      USB Device: Hub, 0x0424  (SMSC), 0x2514, 0xfa100000
      USB Device: LaCie d2 DVDRW USB, 0x0e0f, 0x0001, 0xfa130000
      USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfa140000
      USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0221, 0xfa142000
      USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0xfa120000
      USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0xfa111000
      FireWire Device: Duet, Apogee Electronics, Up to 400 Mb/sec
      thanks
      Message was edited by: Alivalhur Hi, an update to preceding post. I did a lot of maintenance tasks using ONYX and COCKTAIL. No better results so far. As the program worked fine at the first installation, I would like to do a clean re-installation. Someone can advise about which are the files to delete to do that ? Simply deleting the audition.app and the preferences file did not solve the problem; so I guess that there are other files that keep corrupted data. Thanks for your help !!!
        • 1. Re: Repeated crash at launching
          Alivalhur Level 1
          After looking in the WEB I find a procedure to deal with crash problems.
          Hereunder a description of how I proceed in case this can help someone:
          - go to the /Users/{your_account}/Library/Preferences/Adobe/ and delete the "Audition" folder.
          - do a "safe" start-up. To do that you must restart, and as soon as you have the start-up sound push the SHIFT key.
            A progression bar is depicted then. Once the start-up is terminated the log window indicates that the safe mode
              is activated. Note that in this mode your firewire peripherals and others are not available. D'ont care.
          - then log in your account and restart Audition. If this succeed a clean preferences folder is created.
            This also means that the problem arose from a conflict in your acoount, not at the system level.
          - Restart your computer in normal mode. Restart Audition.
          This procedure solved my issue.
          • 2. Re: Repeated crash at launching
            _durin_ Adobe Employee
            Thanks for  following up with your solution.  It does sound as if the Preferences file or the Workspaces file may have become corrupted preventing Audition from launching.  The act of deleting or moving the Preferences/Adobe/Audition/4.0/ folder should have resolved the problem without needing to restart in safe mode.  If the folder/files are not found on launch, Audition will recreate them with the default values.
