I just got a new Literati device, installed everything to get my books on my laptop onto my Literati. However, ADE isn't reading the Literati device and nothing is happening. I can't transfer my book files onto the Literati because ADE isn't authorizing the device and not finding it... I need help with this issue, I'd really like to be able to read my books
I've read elsewhere in the Forum that when you connect your Literati then open ADE, if it does not automatically pop up to authorize your device, you can hit CTRL-SHIFT-E and it will pop up. However, it does NOT work on mine, but it might on yours. Can't hurt to try!
I am having the same issue!
Look at the entry that starts with Literati....How to make the SD card work? It tells you how to get the Literati to connect correctly....make sure to uninstall ADE before you start this process and then follow steps...Hope it works. Once I did it this way it worked right away.
