Files needed to be present to use HTML help and Web help
Guest
Jun 21, 2006 Jun 21, 2006
For using RoboHelp for word generated .hlp files, we kept .hlp and .cnt files in the production environment for the users. Now, we are planning to migrate to Robohelp for HTML help and gradually to WebHelp.
In that case what are the files that are required to be present in the production environment?
356
With HTML Help all you need to ship are the CHM files. That is because these are compiled files that contain all the essential ingredients to see and use the help. The only exception to this rule is if you are using a glossary or browse sequences. In this instance you'll need to ensure all your users have the HHACTIVEX.DLL file installed on their PC. If they don't they won't be able to see them. You cab get the install routine for your application to install and register this file.
With regards to Webhelp, you'll need to publise all the files generated by the compile. Part of the compile process is setting up the location of the published files (e.g. Intranet, FTP). You don't have to worry about what to publish. As long as you have your location correctly defined all the files are copied there.
Guest
Jun 22, 2006 Jun 22, 2006
Do you have any idea, what files are generated during compile other than the .htms?
In essence this depends on the project's contents. However there are potentially a number of javascript files, skin files, etc. that require publishing. The best way to see what has to be delivered is to generate the webhelp output and look in the directory.
RoboHelp Documentation
Download Adobe RoboHelp
