19 Replies Latest reply: Mar 17, 2012 3:33 PM by stephen-apple RSS
    I can't click anything on the settings..
    xoftheuniverse
      Ok so I am trying to use my Dazzle Video capture device to stream video using a webcast system but the flash player settings wont allow me to click anything. I need to change the camera. I can right click and open settings but all the options are not clickable... I am actually using the tab key and return to navigate but I don't think it works on drop menus. Help please.
        • 1. Re: I can't click anything on the settings..
          Paul21967
          No help except to say I am having the same issue.  I am simply at the Disney website and when I right click ->  Settings... the settings window comes up and I cannot click anything.  BIZARRE.  Also with the Disney website the "Loading..." graphic stays on the whole time.
          I also have the problem where the CPU goes to 100% when viewing ANY page the has a flash object on it (disney, espn, etc).  If I disable Flash in the browser the CPU goes down to normal and my laptop eventually cools off.  This is a terrible version of Flash and I hope the developers are working on these issues.
          Note to Adobe:   TEST YOUR SOFTWARE when you get it back from offshore.
          • 2. Re: I can't click anything on the settings..
            xoftheuniverse Community Member
            I am inclined to agree I was helping fix my parents' laptop because it had Adobe reader 7 with Vista.. so, I come here and try to d/l reader 9 and it gets an error... however, I found a link to a reader 9 d/l on the forum, and it worked perfectly fine... This is pretty bad the official site has corrupt files :/ I am not aware of a method to fix this and I really want this flash player to work properly... I hope I can get some help I need to change my camera, and I am sure I am not alone with this issue.
            • 3. Re: I can't click anything on the settings..
              Any ideas how I can change my camera?? I can't click anything at all in the settings.
              • 4. Re: I can't click anything on the settings..
                BWolfe [ADOBE] Community Member
                I guarantee you we put hundreds of thousands of hours into both manual testing and automated testing.  And Flash Player is not developed offshore.
                That said, we've tried about a zillion times to recreate this settings manager failure in-house, and we've never been able to do so. It's not a bug in Flash Player, it's something on your machines -conflicting- with Flash Player.  Driver conflict, video driver problems, other software, etc...
                Try this.
                -- Create a new Administrator profile.
                -- Log in to that admin profile
                -- Launch IE
                -- Install the latest Flash Player 10 from http://www.adobe.com/go/getflashplayer
                -- Go to the settings manager page and test:
                The Flash Player settings manager help is here:
                http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager.html
                On that page, any of the links on the left go to the actual settings manager.
                Report back.
                • 5. Re: I can't click anything on the settings..
                  That didn't help at all I made a new admin user and logged in, tried the flash site and the settings still wont let me click anything, then I looked at the settings manager on site and you cant change the camera from there?? I am using an Intel mac mini with OSX10.5.8 and Safari 4.0.3 and Flash Player 10
                  • 6. Re: I can't click anything on the settings..
                    Well Any other suggestions??
                    • 7. Re: I can't click anything on the settings..
                      zahir herz Community Member
                      From Flash Builder when running a file
                      Error #2044: Unhandled error:. text=Camera access denied by user.  If you wish to view this content, please right/ctrl-click here and click 'settings' to enable your camera, and then refresh this page.
                      From Adobe Flash Player Settings am only able to tab around.  Doesnt recognize mouse click.
                      Please help, project requires Augmented Reality via web cam.
                      UPDATE:
                      Got it working for testing locally.
                      flash player settings manager / website privacy settings / always allow local
                      http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager02.htm l
                      STILL UNABLE TO CLICK ON FLASH SETTINGS PANEL THO.
                      • 8. Re: I can't click anything on the settings..
                        Well I am still stuck completely I need to change settings by clicking the mouse on the settings window because I can't change camera settings via the website. Why does the program not respond?
                        • 9. Re: I can't click anything on the settings..
                          patf9033
                          Same problem here.  YOu go to a page that uses flash, right click and then select settings.  No repsonse to mouse click.  I can tab thru everything but can't change my cam.
                          I'm on a Dell XPS 600 64-bit and running 64 bit windows 7 ultimate.  Have only had this problem since I installed windows 7
                          • 10. Re: I can't click anything on the settings..
                            Yeah thats the same issue alright... except the OS and computer of course.
                            • 11. Re: I can't click anything on the settings..
                              ceaseoleo
                              @Bwolfe,
                              I have to believe that this is a bug in the flash player, as I can provide you examples, where I will go to one site, and the settings will work and I am able to click allow/disallow and, then I can go to another site, where I am unable to click the settings.  I would think if its a conflicting driver problem, then it would be consistent across all sites.
                              • 12. Re: I can't click anything on the settings..
                                eidnolb onlyone Community Member
                                Hi, I see no point in bringing up a year old thread. You would have a better chance of getting a response if you started
                                a thread in your own name.  The person you addressed, as I understand is no longer here.
                                eidnolb
                                • 13. Re: I can't click anything on the settings..
                                  Actually I am still around seeing as this is linked to my email account... but the question remains is there a solution?
                                  • 14. Re: I can't click anything on the settings..
                                    Hi, just getting ready to sign off. I meant that Wolfe was not around, not you. I read your original post. A Mac? I just don't know the Mac's very well. I do know for the Global Settings to work properly, the first thing I would check is to see that
                                    the latest Flash Player files are installed and the SWF plug-in.
                                    Sometimes during an Uninstall of Flash Player an old Flash file may not get removed, etc. That is always the first thing I
                                    suggest to make sure of, since if the Flash Player files are not correct, well it's sort of pointless to proceed.
                                    If I knew the Mac like I do the PC, I could tell you exactly where to check. You probably  know that, so perhaps you already have.
                                    What you might do, is start a new thread and be sure to mention Mac in the subject line. I have seen someone help and then are quite smart with the Mac.
                                    That is all I can suggest. I was trying to help someone about a week or so ago and if I can find the thread I'll post it here.
                                    Ok, I found it. Don't know if it will help.
                                    http://forums.adobe.com/message/2667346#2667346
                                    eidnolb
                                    • 15. Re: I can't click anything on the settings..
                                      cst95959
                                      Same Problem, using Windows 7, 64bit, New Dell Inspiron N7010.
                                      Trying to use a cam on a web site.
                                      When adobe setting box appears, mouse does not work, space bar and tab work but
                                      can not change setting in drop down box.  There should be a seperate manager that
                                      can be intergrated into windows or run as a seperate program.. This has happend on
                                      almost every machine I have ever owned... we're talking 12 pc's and laptops, if not
                                      more... I am a high end user, with  29 years of windows experience.....
                                      if you can recreate this on your tech pc's then have one of use do a dump of
                                      everything running and try it or maybe you have the wrong people working on the problem.
                                      It should be easier to find answers to problems by using help, and not have to resort to forums.
                                      Possibly you need a good tech writer....
                                      • 16. Re: I can't click anything on the settings..
                                        patf9033 Community Member
                                        Here is what I have done to work around the problem.  Start the flash settings window and then
                                        1.       Tab to camera icon
                                        2.       Hit enter
                                        3.       Tab to drop down menu
                                        4.       Cntl + up arrow
                                        5.       Hit enter
                                        6.       Tab to cam
                                        7.  hit enter
                                        8.  tab to exit
                                        9.  hit enter
                                        • 17. Re: I can't click anything on the settings..
                                          cst95959 Community Member
                                          Thank You patf9033 for your response..... it didn't quite work the same way it did for you but,
                                          I was able to change my camera settings. It still should be addresed by Adobe.
                                          I don't think they are listening to customers, and we know there are more then just a few of use.
                                          I had two cameras, one built in web cam and the other external, I disabled the internal in order to change
                                          setting on the internal.... .   Thanks for your work around... still would like the mouse to work...
                                          • 18. Re: I can't click anything on the settings..
                                            connorsmacartist
                                            This is absolutely ridiculous they still haven't fixed this. This is a horrible bug and its been there for 2 years. I think it has to do with the window mode when the flash player is embeded but it shouldn't show a panel the user can't click. Its crap like this that people are leaving flash is droves.
                                            • 19. Re: I can't click anything on the settings..
                                              stephen-apple Community Member
                                              Use a series of [TAB]'s and [SPACE]'s to move and select respectively. This worked in Chrome (17) on the MAC (10.7) after not being able to click on the settings manager within a webpage.
                                              This isn't a permissions issue or a page issue, it's a Flash issue. Adobe claim they cannot recreate the issue in house to troubleshoot it so if any of you are near 345 Park Avenue San Jose, CA consider walking your computer into Adobe and show them. I suspect it's client specific.
