I have just received an Elonex Ebook 621eb and have gone through the process of downloading ADE and it has authorised my computer, however when I connect the Ebook via the usb to the computer nothing happens - it does not come up with the Adobe ID to authorise the device. I know the Ebook works as we have downloaded a pdf file and pasted it into the ebook as it appears on the H Drive in my computer.
Does anyone have any ideas on how I can get it to work via ADE ?
Thanks Sarah
Had the same problem - this worked for me - Disconnect the e-reader from the PC, go to Settings, Default on the reader and select/enter - this restores the factory settings - then try reconnecting to the PC and see if ADE then recognises. Good Luck
Not an expert, but a suggestion/question. Did you plug in the ereader first, then open ADE? Apparently, ADe
automatically finds the device and then asks you to register. Didn't happen for me though! But since yours is a supposedly compatible devi
ce (see here:
http://blogs.adobe.com/digitalpublishing/supported-devices) it should work.Copy link to clipboard
Thankyou very much for replying and your advice. I tried the other reply first and this worked so I am now
happy.
cheers Sarah
Thankyou so much ! This worked and I can now finally enjoy my Xmas present.
Cheers Sarah
