I am having a problem in updating the value in XML variable using SetValue (by XPATH expression). It is deleting my original XML and replacing it by new one. I am out of clue why it is happening so.
My Steps:
1. I have created a variable as XML type and Set it as INPUT, REQUIRED.
2. I am updating this variable using Set Value activity. In my process it is 'locUpdate1'
The original XML is: (value of xmlData)
<xdp:xdp xmlns:xdp="http://ns.adobe.com/xdp/" xmlns:dd="http://ns.adobe.com/data-description/" xmlns:xfa="http://www.xfa.org/schema/xfa-data/1.0/" timeStamp="2011-01-03T07:31:26Z" uuid="009257fd-3f66-449d-b554-6a095f917b74">
<xfa:datasets>
<xfa:data>
<GetUserRoot>
<applicantInformation>
<UserInfo>
<UserID1/>
<UserName1/>
<UserID2/>
<UserName2/>
<UserID3/>
<UserName3/>
<CurrentUserID>6967A5DE-D5EB-102D-BF7F-0000C0A8010C</CurrentUserID>
<CurrentUserName>Sarah Rose</CurrentUserName>
</UserInfo>
</applicantInformation>
<FSTARGETURL_/>
</GetUserRoot>
</xfa:data>
<dd:dataDescription dd:name="GetUserRoot">
<GetUserRoot>
<UserInfo>
<UserID1/>
<UserName1/>
<UserID2/>
<UserName2/>
<UserID3/>
<UserName3/>
<CurrentUserName/>
<CurrentUserID/>
</UserInfo>
</GetUserRoot>
</dd:dataDescription>
</xfa:datasets>
<pdf xmlns="http://ns.adobe.com/xdp/pdf/" href="-4608764380271080676-28"/>
<xfdf xmlns="http://ns.adobe.com/xfdf/" xml:space="preserve">
<annots/>
</xfdf>
</xdp:xdp>
After Operating it is changing to
<GetUserRoot>
<UserInfo/>
</GetUserRoot>
which should not be done.
I just want to copy one element's value into another.
/process_data/xmlData/GetUserRoot/applicantInformation/UserInfo/UserID1 = /process_data/xmlData/GetUserRoot/applicantInformation/UserInfo/CurrentUserID
Result Should be:
<xfa:datasets>
<xfa:data>
<GetUserRoot>
<UserInfo>
<UserID1>6967A5DE-D5EB-102D-BF7F-0000C0A8010C</UserID1>
<UserName1>Sarah Rose</UserName1>
<UserID2/>
<UserName2/>
<UserID3/>
<UserName3/>
<!-- this is to be coiped in above -->
</UserInfo>
<FSTARGETURL_/>
</GetUserRoot>
</xfa:data>
<GetUserRoot>
<UserInfo>
<UserID1/>
<UserName1/>
<UserID2/>
<UserName2/>
<UserID3/>
<UserName3/>
<CurrentUserName/>
<CurrentUserID/>
</UserInfo>
</GetUserRoot>
</xfa:datasets>
<annots/>
</xfdf>
</xdp:xdp>
Any help what I am doing wrong.
Thanks.
Abhinav
Solved! Go to Solution.
Total Likes
Your assignment is incorrect. Note that you must refer all the nodes of XML (right from the ROOT node)
Since your node reference is not absolute,it will create nodes as you defined in your left-side expression.
The following code should work as you expected!
/process_data/xmlData/xdp/datasets/data/GetUserRoot/applicantInformation/UserInfo/UserID1 = /process_data/xmlData/xdp/datasets/data/GetUserRoot/applicantInformation/UserInfo/CurrentUserID
Nith
Total Likes
Nith
Total Likes
