Captivate 5 seems to cling to project title names, and I can't figure out how to reset them. For example, I have a file named Section_OrderEntry.cptx. When I go to File > Publish and the Publish dialog opens, the default Project Title it gives me is: Adding User_demo. I believe the name and the "_demo" extension are a result of the file originally being created and saved when my Captivate was in its 30 trial. I've since purchased the eLearning Suite.
Any ideas on where I can reset the default Project Title? I want it to be the same as the file name. Thanks!
I've seen this behaviour at times as well. What I usually do to fix it is:
Thanks, Rod! I've got a lot of projects, so this is definitely going to save me time!
Hi all
For what it's worth, I'm hoping that you and anyone else encountering the issue will take a few moments and report this to Adobe as a bug. That way it will be on their radar to be fixed in either a patch or in the next release. (Link to the bug report is in my sig)
Cheers... Rick
Helpful and Handy Links Begin learning Captivate 5 moments from now! $29.95 Captivate Wish Form/Bug Reporting Form |
Thanks, Rick! I did in fact report the bug. Here's what I sent:
Steps to reproduce bug:
The learning module I'm creating is actually several projects that need to be connected. For example, users viewing Project A will at some point have the option to click a link to go to Project B. So within Project A, I have created a "Go to Project B" button, which I have given an action of "Open another project" and selected the Project B Captivate file as the target. Both Captivate files are in the same folder; the published SWF and HTM files are also in the folder.
Results:
When I view Project A in a browser and I click the "Go to Project B" button, nothing happens. The cursor changes to a hand to indicate the link, but nothing happens after the click.
Further, I understand this to be a Flash Player security issue. And I have followed the convoluted steps to get around this. But even when I do, the results are mixed -- sometimes it works, sometimes not. And even when I place the files on a web server and access them NOT from my local machine, the buttons don't work.
Expected results: When I set a button action to open another project, I pretty much expect the button to open the project.
Hi there
Methinks you may be thinking of a different thread and a different issue? This thread seems related to the Name used when publishing. To my knowledge, it has nothing to do with linking.
Cheers... Rick
Ah! That's what I get for responding to email instead of in the forum. I will report this bug, too.
I'm encountering the issue as well and have taken a moment to report this to Adobe as a bug. Here is what I submitted (hope this will be understood):
******BUG******
Concise problem statement:
Captivate 5 seems to cling to old project title names
1. I have a project named Ex155C.cptx. .
2. When I go to File > Publish and the Publish dialog opens, the default Project Title it gives me is: Ex150.
Results:
The default Project Title it given as: Ex150 (instead of Ex155C). I believe the name is retained from a file formerly being created and saved.
When the Project Title is corrected saved once, next time the wrong old default title reappears.
Expected results:
Need the default Project Title every first time to be the same as the file name, after that the Project Title from last publishing / saving must be retained.
I'm suffering from the same bug. Thanks for your workflow - following this the project title was adjusted.
I attempted this fix, and still get the old project title every time.
Anyone have any other suggestions?
Thanks, Ron!
This worked for me, though I wish Adobe would fix the bug.
