Hi all,
I previously used Flex Builder 3 on Vista x64. Inside Flex Builder 3, I had both flex projects and java projects. I needed both because I use BlazeDS and kept the java code in a separate project. I would only like 1 development environment.
I recently upgraded to Windows 7 x64 and went ahead and upgraded my Flex Builder 3 to Flash Builder 4.
It was a simple measure to import my flex projects into Flash Builder 4.
When I tried to import the Flex 3 java projects into Flash Builder 4, Flash Builder responded with:
" The folder does not contain a valid Flash Builder Project."
Short of installing Eclipse, a 32bit version of java, and using the Flash Builder Plugin, is there a way to get my java projects to import and compile in Flash Builder 4 while running on Windows 7 x64?
Thanks in advance for any thoughts,
- Steve
P.S. I may have had to import something special to get it to work in Flex Builder 3, I just can't remember.
If you're trying to compile Java projects in FB4, you'll need to add eclipse's Java Development Tools (JDT).
You can add the JDT this way:
- quit FB4, and launch with "Run as Administrator" from the context (right-click) menu
- from the Help menu choose "Install New Software..."
- in the resulting dialog click "Add", and enter a name of your choosing such as "Galileo Updates" in the Name field
- enter this URL into the Location field:
http://download.eclipse.org/releases/galileo/
- hit OK and then browse the available Galileo Updates
- select Programming Languages > Eclipse Java Development Tools
- continue on with the usual Update workflow, and after finishing it will prompt you to relaunch automatically.
Allow FB4 to relaunch, and you should now have the JDT available for compiling Java projects.
-Chris
Hi Chris,
Superb! Thanks!
- Steve
Does this apply for Flash Builder 4.7? Is the update site the same?
One more question, would I be able to open the Java project through "import an existing project" menu item?
Hi I would like to know the same answer. Thanks
