I am trying to put data into my db that is a date string from a .csv file, this is the format it's in from the file: 3/3/1952 (example)
this is my query:
<cfquery name="importcsv" datasource="#APPLICATION.dataSource#">
INSERT INTO employees (siteID,empstatus,empfirstname,empmiddlename,emplastname,empnickname, emplocation,empgender,empdob,empdoh,empee)
VALUES
(<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#trim(listgetAt(i,1))#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,2)#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,3)#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#trim(listgetAt(i,4))#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,5)#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,6)#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,7)#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,8)#">,
<CFQUERYPARAM cfsqltype="cf_sql_date" VALUE="#DateFormat(CreateODBCDate(ParseDateTime(listgetAt(i,9))), 'MM/DD/YYYY')#">,
<CFQUERYPARAM cfsqltype="cf_sql_date" VALUE="#DateFormat(CreateODBCDate(ParseDateTime(listgetAt(i,10))), 'MM/DD/YYYY')#">,
<CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,11)#">
</cfquery>
This is the line giving me the problem:
Can anyone help me get thi sworking properly? I've been looking at all kinds of documents and web tricks and it's not working.
Thank you
Please show us a sample line of the data file, and also tell us the CF error that you are getting.
-reed
Sorry, this is the error:
empdob is an invalid date or time string.
The error occurred in f:\websites\211562fe3\partners\cfm\csvUploadAction.cfm: line 58
56 : <CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,7)#">,
57 : <CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,8)#">,
58 : <CFQUERYPARAM cfsqltype="cf_sql_date" VALUE="#DateFormat(CreateODBCDate(ParseDateTime(listgetAt(i,9))), 'MM/DD/YYYY')#">,
59 : <CFQUERYPARAM cfsqltype="cf_sql_date" VALUE="#DateFormat(CreateODBCDate(ParseDateTime(listgetAt(i,10))), 'MM/DD/YYYY')#">,
60 : <CFQUERYPARAM CFSQLTYPE="cf_sql_varchar" VALUE="#listgetAt(i,11)#">
The rest of the code is in my other post, the date appears in the .csv file like this: 00/00/0000 and it won't take it in my query, the table is also set for date and it's an access database.
The error seems pretty clear. The value "empDob" is not a date. Perhaps your file has a header row you are inadvertently trying to load?
Thanks for this. I forgot I had a header row in the spreadsheet.
If you run into an invalid date value in your CSV do you want to substitute a NULL value? You could do something like:
<cfqueryparam cfsqltype="cf_sql_date" value="#listgetAt(i,9)#" null="#YesNoFormat( IsDate(listgetAt(i,9)) neq true )#">
You might also try using cfsqltype="cf_sql_timestamp". That is the cfsqltype that works for MS SQL DateTime fields, it may also be appropriate to use in MS Access.
I fixed the date time problem, but now this code is giving me a data mismatch..
It's all correct from what I see.. it says the problem is in line 60, that's the last cfqueryparam in the input. It is marked as a text field
with the number 10 in it and the cfqueryparam is set as variablechar.
Here is my error:
Error Executing Database Query.
[Macromedia][SequeLink JDBC Driver][ODBC Socket][Microsoft][ODBC Microsoft Access Driver] Data type mismatch in criteria expression.
The error occurred in C:\websites\211562fe3\partners\cfm\csvUploadAction.cfm: line 60
58 : '#listgetAt('#index#',9, ',')#', 59 : '#listgetAt('#index#',10, ',')#', 60 : '#listgetAt('#index#',11, ',')#') 61 : </cfquery> 62 : </cfloop>
This is my query now:
VALUES
<cfqueryparam cfsqltype="cf_sql_date" value="#listgetAt(i,9)#" null="#YesNoFormat( IsDate(listgetAt(i,9)) neq true )#">,
<cfqueryparam cfsqltype="cf_sql_date" value="#listgetAt(i,10)#" null="#YesNoFormat( IsDate(listgetAt(i,10)) neq true )#">,
</cfquery>
and this is the line from the .csv file I'm trying to upload into the database:
12,active,Douglas,L,Berg,none,Marshall,MN,Male,3/3/1952,3/3/1952,none
It should all go in with no problem, what am I missing here?
Thank you for all the help so far. It seems to have satisfied the date problem.
Please post more of your code:
1. More of your code. It would be useful to see how your loop is executing.
2. The definition of your table structure.
Regarding: The definition of your table structure.
Especially the siteid field.
