I'm baaaack!
Craig and Pete, thank you for the previous info. It enabled
our developers to fix MOST of the "Always on Top" problem. However,
with some dialog boxes, the Help continues to stay on top after
opening another program, when it shouldn't. Example scenario: 1)
Open my software program, on the File menu, open the XYZ window,
click add (the Add XYZ dialog box opens) - it is from this dialog
box that I open Help. Help's on top which is fine, but when I open
Note Pad (or any other program), Help still stays on top.
Is there a way to correct that, so that Help goes behind, or
is it that with dialog boxes that are open, we're just out of luck?
Thanks so much for any info you have.
