How can I repair the "view selected item" or "eyeglasses"? Each time I click on it nothing pops up. Thank you!
Hi there
What sometimes happens is that the preview window becomes moved to a position vastly off the screen. I call it "the computer's version of pluto".
Oddly, I've never noticed this until moments ago. Maybe things behaved differently in XP. I'm using Windows 7 so perhaps that changes my playing field.I sure seem to recall that previewing would focus the preview window and RoboHelp would appear to be locked up until you dismissed it. But I just looked at version 8 and it's allowing the preview
...Copy link to clipboard
Hi there
You can do this an easier way.
Preview
Press Alt+Spacebar, then M.
Press any of the arrow keys.
Wiggle the mouse around and see if the preview pops into view.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Thanks for that RIck. That was a new one on me.
Note to self : update blog post!
The RoboColum(n) | @robocolumn | Colum McAndrew |
Hi Colum
It's a nice easy solution.
To be totally honest, I believe it was Amebr that came up with that solution. So if you update the post and want to give credit where it's due...
And that's actually embarrassing to me! I fancy myself a good keyboard person because I worked in a call center for a good number of years. That and I'm always trying to make things as simple as I possibly can.
Cheers... Rick
Thank you both for your prompt reply.
Capitv8r,
I tried what you suggested a couple of times and nothing happened. I just get a quick hourglass but nothing appears for me to preview.
Column,
I cannot read your post as my organization "blocked" it on websense.
Hi there
Oddly, I've never noticed this until moments ago. Maybe things behaved differently in XP. I'm using Windows 7 so perhaps that changes my playing field.I sure seem to recall that previewing would focus the preview window and RoboHelp would appear to be locked up until you dismissed it. But I just looked at version 8 and it's allowing the preview to remain open and the preview window doesn't remain focused. Grrr
Perhaps try closing and restarting RoboHelp. Then carefully open a topic. Carefully preview. Immediately after you invoke the preview, try the steps outlined.
Give that a go and let us know how you fare... Rick
Captiv8r,
Thank you, thank you, thank you!!! It worked! It obviously was off in "planet pluto land"! It worked! Thanks again -- I just can't live without this preview option -- so much appreciated!
Cheers to you too!
Hi there,
There is a program called ForceWindowVisible available from http://www.compendiumdev.co.uk/forcedisplay/ which gives a list of ALL windows, allowing you to bring them on-screen. I found it rather clumsy (mainly because there are dozens of "windows" listed) but for me it worked even when Amebr's brilliant trick didn't. Therefore I kept it in my toolkit. I guess I use Amebr's trick about once a week, and ForceWindowVisible about once a year.
--- Derek
