Show 4 replies
1. Re: Problem with PSE 8 (Mac)
MTSTUNER Jan 7, 2011 1:59 AM (in response to henni77)Two things you might try:
Reset the pse8 preferences by holding down the Cmd-Option-Shift keys
when you launch the pse8 editor and click ok (yes) in the dialog that
appears.
If that doesn't solve the problem, look for a stuck Shift key on your
keyboard.
MTSTUNER
2. Re: Problem with PSE 8 (Mac)
henni77 Jan 7, 2011 2:18 AM (in response to MTSTUNER)Tried both, but didn't work...
I just discovered that it is also with the brush. Only perpendicular or horizontally lines possible...
3. Re: Problem with PSE 8 (Mac)
MTSTUNER Jan 7, 2011 3:17 AM (in response to henni77)You might read this post for other possible causes:
http://forums.adobe.com/thread/752602
It pertains to the full photoshop, but there may be a solution that
works for elements also.
It seems only to be an issue with 10.6.5 and the full photoshop
so far.
MTSTUNER
4. Re: Problem with PSE 8 (Mac)
henni77 Jan 7, 2011 3:31 AM (in response to henni77)It Helped!
Thanks a lot!
