1. Re: Problem Filling and Selecting with Paths.jsx
Kenneth Evans Jan 8, 2011 2:37 PM (in response to Kenneth Evans)This is the whole script:
// Paths.jsx
#target photoshop
// Save the current preferences
var startRulerUnits = app.preferences.rulerUnits
var startTypeUnits = app.preferences.typeUnits
var startDisplayDialogs = app.displayDialogs
// Set Adobe Photoshop CS5 to use pixels and display no dialogs
app.preferences.rulerUnits = Units.PIXELS
app.preferences.typeUnits = TypeUnits.PIXELS
app.displayDialogs = DialogModes.NO
// First close all the open documents
while (app.documents.length) {
app.activeDocument.close()
}// Create a document to work with
var docRef = app.documents.add(5000, 7000, 72, "Simple Line")// line 1--it’s a straight line so the coordinates for anchor, left, and right
// for each point have the same coordinates
var lineArray = new Array()
lineArray[0] = new PathPointInfo
lineArray[0].kind = PointKind.CORNERPOINT
lineArray[0].anchor = Array(100, 100)
lineArray[0].leftDirection = lineArray[0].anchor
lineArray[0].rightDirection = lineArray[0].anchor
lineArray[1] = new PathPointInfo
lineArray[1].kind = PointKind.CORNERPOINT
lineArray[1].anchor = Array(150, 200)
lineArray[1].leftDirection = lineArray[1].anchor
lineArray[1].rightDirection = lineArray[1].anchor
var lineSubPathArray = new Array()
lineSubPathArray[0] = new SubPathInfo()
lineSubPathArray[0].operation = ShapeOperation.SHAPEXOR
lineSubPathArray[0].closed = false
lineSubPathArray[0].entireSubPath = lineArray// line 2
var lineArray2 = new Array()
lineArray2[0] = new PathPointInfo
lineArray2[0].kind = PointKind.CORNERPOINT
lineArray2[0].anchor = Array(150, 200)
lineArray2[0].leftDirection = lineArray2[0].anchor
lineArray2[0].rightDirection = lineArray2[0].anchor
lineArray2[1] = new PathPointInfo
lineArray2[1].kind = PointKind.CORNERPOINT
lineArray2[1].anchor = Array(200, 100)
lineArray2[1].leftDirection = lineArray2[1].anchor
lineArray2[1].rightDirection = lineArray2[1].anchor
lineSubPathArray[1] = new SubPathInfo()
lineSubPathArray[1].operation = ShapeOperation.SHAPEXOR
lineSubPathArray[1].closed = false
lineSubPathArray[1].entireSubPath = lineArray2// Ice cream curve
// It’s a curved line, so there are 3 points, not 2
// coordinates for the middle point (lineArray3[1]) are different.
// The left direction is positioned "above" the anchor on the screen.
// The right direction is positioned "below" the anchor
// You can change the coordinates for these points to see
// how the curve works...
var lineArray3 = new Array()
lineArray3[0] = new PathPointInfo
lineArray3[0].kind = PointKind.CORNERPOINT
lineArray3[0].anchor = Array(200, 100)
lineArray3[0].leftDirection = lineArray3[0].anchor
lineArray3[0].rightDirection = lineArray3[0].anchor
lineArray3[1] = new PathPointInfo
lineArray3[1].kind = PointKind.CORNERPOINT
lineArray3[1].anchor = Array(150, 50)
lineArray3[1].leftDirection = Array(100, 50)
lineArray3[1].rightDirection = Array(200, 50)
lineArray3[2] = new PathPointInfo
lineArray3[2].kind = PointKind.CORNERPOINT
lineArray3[2].anchor = Array(100, 100)
lineArray3[2].leftDirection = lineArray3[2].anchor
lineArray3[2].rightDirection = lineArray3[2].anchor
lineSubPathArray[2] = new SubPathInfo()
lineSubPathArray[2].operation = ShapeOperation.SHAPEXOR
lineSubPathArray[2].closed = false
lineSubPathArray[2].entireSubPath = lineArray3// Create the path item
var myPathItem = docRef.pathItems.add("A Line", lineSubPathArray)// Stroke it so we can see something
myPathItem.strokePath(ToolType.BRUSH)// Fill the path
fillColor = new SolidColor
fillColor.rgb.red = 255
fillColor.rgb.green = 0
fillColor.rgb.blue = 0
try {
if(false) {
// This works and gives a gray fill that is neither the
// foreground nor background color
// Only the ice cream part of the cone is selected and filled
myPathItem.fillPath()
} else if(false) {
// With a color specified, it doesn't work
myPathItem.fillPath(fillColor)
} else if(true) {
// This makes a selection of the PathItem, selects it and fills it
myPathItem.makeSelection(0, false, SelectionType.REPLACE)
selRef = app.activeDocument.selection;
selRef.fill(fillColor, ColorBlendMode.NORMAL)
} catch(ex) {
msg = "Error filling path:\n" + ex.message
alert(msg, "Exception", true);
}// Reset the application preferences
preferences.rulerUnits = startRulerUnits
preferences.typeUnits = startTypeUnits
displayDialogs = startDisplayDialogs -
2. Re: Problem Filling and Selecting with Paths.jsx
Michael L Hale Jan 8, 2011 3:15 PM (in response to Kenneth Evans)It's not a bug. The path you created has 3 open subpaths, two of which are lines. Fill does not work on open lines. It will fill open arcs and/or closed paths.
One way to be able to fill the cone would be to create it as a three point closed path instead of just two lines.
3. Re: Problem Filling and Selecting with Paths.jsx
Kenneth Evans Jan 8, 2011 5:19 PM (in response to Michael L Hale)Yes. I figured that out myself after going away and thinking about it. (I didn't get back in time ;-) It takes 5 points, including the end. But thanks, it must have been much harder for you to read my code and see that than for me.
I am still left with the problem with method two:
General Photoshop error occurred. This functionality may not be available in this version of Photoshop
- Could not complete the command because of a program error.
The Object Model Viewer says the first argument is any, but the Reference Manual says it is a SolidColor. Perhaps I am using it wrong. In Photoshop in the Paths panel, it fills with the foreground color. Method 1 filled it with a medium gray. Method 2 is what I tried first and the most straightforward way, I think.
Thanks again.
4. Re: Problem Filling and Selecting with Paths.jsx
Michael L Hale Jan 8, 2011 5:27 PM (in response to Kenneth Evans)The guide does make it look like all the arguments are optional but it seems that if you supply the color you must also supply at least some of the other arguments. Your code works for me if I supply all the arguments
myPathItem.fillPath(fillColor,ColorBlendMode.NORMAL,100,false,0,true,true);
5. Re: Problem Filling and Selecting with Paths.jsx
Kenneth Evans Jan 8, 2011 8:56 PM (in response to Michael L Hale)It seems to work for me too. Thanks.
I appologize for not marking it as a correct answer. Actually what I did was mark the first answer as correct and then the second as helpful. Only the latter seemed to remain. I am new at this forum. If you can tell me how to fix it, I will.
In any event I appreciate the help and both answers were correct.
