I just installed FB Burrito and opened up my workspace containing projects using Flex 4.0 SDK, and I see that I get compile errors when for my css files that are set to be compiled to swf files.
Description Resource Path Location Type
A file found in a source-path must have the same package structure 'assets.sounds', as the definition's package, ''. defaultSoundTheme.css /ProjectName/src/assets/sounds Unknown Flex Problem
A file found in a source-path must have the same package structure 'assets.styles', as the definition's package, ''. player.css /ProjectName/src/assets/styles Unknown Flex Problem
Looks like a regression.
- Abey
This is a known regression and we're investigating a fix for this.
Meanwhile, as a workaround, can you quickly see if moving the CSS file to your src/ folder helps?
Anirudh
I confirm this existing issue with compiling css to swf.
And, no, moving CSS files to "src" folder does not help, still receiving an error like
AllEastAsian.css A file found in a source-path must have the same package structure 'css.locale', as the definition's package, ''
Any update to this in last 2 months? I also can't run my project in Burrito due to these CSS files being compiled to SWF.
This has been fixed in the later builds of Burrito. However, none of those builds are publicly available and I don't have info about when they will be.
When there is any news regarding this, I'll keep this thread updated.
Awesome - thanks for the quick update. Everything has seemed very promising (coming from FB3) but I can wait a bit longer.
You can join a private FB Burrito beta, email "Shorten at adobe.com if you'd like to join the prerelease."|
Hi, to back out this *attempt* remove the following which in my case was added to .actionScriptProperties file
<buildCSSFiles>
<buildCSSFileEntry destPath="bin-debug" sourcePath="src/css/Demo.css"/>
</buildCSSFiles>
Replace with:
</buildCSSFiles>
HTH,
Mark Simon
