Hi all,
I am not able to get the values GetUsers() functions via a c# service. Do you know why? <cfdump outfut all the functions names of that webservice..
<cfset
x = cfobject("webservice","http://w9s312c1/WebService/Store.svc?wsdl") >
<cfset
e = x.getUsers()>
<cfdump
var="#e#">
You didn't provide nearly enough information for anyone to help you.
What kind of error are you getting? If you're not getting an error, what's happening exactly?
What kind of object is the C# service supposed to return?
If you don't get an error, what happens when you invoke some of those functions?
Dave Watts, CTO, Fig Leaf Software
http://www.figleaf.com/
http://training.figleaf.com/
There is no error. but not getting values of that function. that function has email, first, last name fields.
Are you able to invoke any of the other functions? What exactly does that function return? An array containing the three fields, or something else?
it returns bunch of function names, and return types not the values. And when I looked the output source code it has wsdl/xml content.
When you dump the GetUsers function, are there other functions you can invoke from there?
yes there are
What happens when you invoke those functions?
Please see the attached image.
It looks to me like your function returns an object containing an array of User objects (whatever they are). You need to basically drill down until you get something that can be converted to a string. So, take the current object you're dumping, then invoke GetUser(1) (for example), then dump that, etc, etc.
a function called "m" returns a single value works and return the value but not getusers(), getusers return that dump structure.
