I'm using Robohelp HTML version 8.
When viewing a topic properties, the General and Advanced tabs are displayed, but I haven't found how to display the Index tab in this version.
Is this option not available in version 8?
Thanks for the screen shot. I see what is happening now. What you are seeing is the properties of the TOC Page not the actual topic properties. This occurs when you click Properties with the TOC page selected. If you have the cursor inside the topic's WYSIWYG (or select the topic in the Topics List pod or Project Manager pod) right click on it and select Topic Properties, you'll get the Index tab.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Hi Cecil27 and welcome to the RH community.
Are you only seeing those two tabs? You should be seeing others as well (e.g. Status, File, See Also). Also where is your project located? If it is on a network drive, move it to a local drive and see if the problem still occurs.
Yes, those are the only tabs being displayed.
The project is saved in the local drive.
Thanks, this solved the problem!
